Mystery pulley
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Topic: Mystery pulley
    Posted: 24 Jul 2023 at 5:15pm
On a WD45. Have recently been prompted to get this tractor up and running again and I noticed this 3 groove pulley on the PTO shaft underneath
Looks like it would be a real challenge to install belts. Am wondering if this is related to a side mounted sickle mower that's here or is this for some other attachment?
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2023 at 7:59am
Interesting. Never seen anything like that before. Would make removing the p.t.o. shaft a bit of a challenge!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2023 at 12:26pm
Side mount Sickle mower?
Belly mower?
Extra hydraulics?
Sprayer pump?
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2023 at 12:39pm
There is a side mount sickle mower here that I believe was my dads but don’t ever remember powering that way. Was a shaft that ran forward to it. The under mount was similar
This tractor has been here since I can remember. Possibly was owned by a late uncle then became my grandfather’s. Only thing I I’d seen mounted to it was a row cultivator. This one has power steering, narrow front, and Vinson manifold on it. Wheels have been repainted and cream colored wheels
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2023 at 5:03pm
It was used for adding a hyd pump some had chain drive instead one of the neighbor had one on a WC it work pretty good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2023 at 10:51pm
Interesting. Did it use use all three belts or just one relative to position? Be neat to see that. There is an unstyled WC in the chicken house that has a remote hydraulic pump and reservoir to operate the loader. It runs off the belt pulley.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2023 at 9:18am
Kosch used something similar 3 pulleys to match the different size pulleys on the mower to change speeds
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2023 at 11:17am
The allis mower drove on an bbn offset shaft running of the back of the PTO. I have seen a couple loaders hyd pumps running off a pulley with a double belt and one with a chain like that they were fRmer dabbed. If you pull one bolt in the pto box end the shaft will slide back and you could put a belt on very easy
