175 hydraulics
Kirkp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kirkp Quote  Post ReplyReply Direct Link To This Post Topic: 175 hydraulics
    Posted: 15 Mar 2022 at 10:11am
Working on a 175 no hydraulics, dropped sump no oil yet dip stick to left of shifter says full
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2022 at 12:36pm
Well, if there's no oil in the hydraulic/torque tube sump, you'd expect the hydraulics not to work. Hard to believe the screw-in dipstick has any oil on both sides of it after being wiped clean and re-inserted for an oil level check. I think you need to drain the plug directly under the clutch pedal, carefully clean the screen above the sump and refill with 5 to 5 1/2 gallons of oil. Then, I know it's full.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2022 at 8:58pm
If you drained system for some reason and refilled, it takes a while for oil to get up to there. Unhook return line on left side to help vent system                    MACK
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2022 at 10:10pm
side or front pump?
