Plow tires
Rod in MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod in MN Quote  Post ReplyReply Direct Link To This Post Topic: Plow tires
    Posted: 10 Sep 2018 at 2:51pm
HI I have a 2 bottom plow and I was wondering what tires I should put on the stubble Wheel and on other front wheel the size is 6.00x16. where is a good place to get them?
Thank You
Rod
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 3:37pm
They have what's called a "traction implement" tire that I would put on the stubble wheel, basically like a miniature version of a rear tractor tire but the bars run backward. I would put a smooth implement tire on the furrow wheel and a single rib on the back if it has one. Miller Tire has a Firestone "Power Implement" tire and "Rib Implement" tire listed under 6.00-16 implement tires that would look period correct for your plow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 5:58pm
You just mount the tire backwards(as compared to a rear tractor tire), on the rim, to make the traction tire work correctly...Wink
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 6:12pm
Plow tires.
   if your plow has a rubber tired tail wheel , most run at a angle you should get the correct one as all others will not run with the full tread contacting the ground and could cause the plow not to trail rite.
This page was generated in 0.547 seconds.
