Fence row D14 |
Post Reply | Page <12 |
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8167 |
Dave,
Maybe that is the problem. I told him we should bolt the cross bar on the drawbar. Will have to look at a little more. We did not have any numbers on where the lower arms should have been. Matt said it worked fine for his back blade and brush hog. Anyway it was a good event for a old man to help a young man. He buzzed wood with it last night using the 9N and said it worked good. Regards, Chris
only AC orange
Silver Level Access Joined: 06 Dec 2014 Location: Eastern Indiana Points: 383 |
Looks like left rear tire is either Firestone traction champion or BF Goodrich power grip? If and when your "Buddy" changes to combine tires, what would be chance of dealing for left rear if it is a BF Goodrich power grip ? Looking for a mate to one on my D-14! Thanks, M. Roush
Sugarmaker
only,
I dont think he has any plans for tire swaps at this time. But I will let him know. Regards, Chris
Rick of HopeIN
Orange Level Joined: 11 Sep 2009 Location: Hope, Indiana Points: 1296 |
I got to try out my Grandpa's when I was about 9 mos old. I suspect this was spring of 1957. 40 Cockshutt in background. Would be nice to have that one too. Edited by Rick of HopeIN - 01 Feb 2020 at 8:53pm |
tony
Silver Level Joined: 17 Oct 2011 Location: deper wi Points: 76 |
I think your 3point problem mite have something to do with how the top link is mounted. Looks like it's too high. Add some plates with holes drilled to the back so you can install the top link lower.
After looking at the pic with the saw rig on, I'm fairly certain it's the top link mount that's the problem. The top link should be pretty much at the same angle as the arms when hooked up. Otherwise as you found out, the implement will "tip" as you move the arms up or down. Edited by tony - 02 Feb 2020 at 6:00am |
Ross D.
Silver Level Joined: 02 Sep 2013 Location: Erin, Ont. Points: 338 |
Good morning. Google has a lot of information on 3Pt. specifications. Note the position of this 3rd point. Ross.
Sugarmaker
Rick, Tony, Ross,
Thanks for the comments! Yes we may have two issues the actual 3 point lower arms may not be out past the tractor far enough. And we may have the top link pivot too high. Well it was a farmer fix and not a lot of dimensions or specs were reviewed during the build. Thats' what happens! Regards, Chris
Reindeer
Orange Level Joined: 14 Sep 2009 Location: Calgary, AB Points: 649 |
I put a 3 of kit on my D15, and had the same problem. Found a shorter top link online, about 13" minimum length. That seems to have resolved the problem with my " selfunloading" 3pt carryall.
MDWilliams338
Silver Level Joined: 19 Nov 2018 Location: NC Points: 473 |
I gotta get out of the shop! How’d I miss this find and save?!? Nice going though😬
It isn’t how you die.It’s what you live for.-Daniel Boone |
ACinSC
Orange Level Joined: 16 Dec 2015 Location: South Carolina Points: 2516 |
My D 15 top link was too long to hook up the harrow . About 22" at shortest adj. Short top link set about 20" works . Short top link body is 13" as said . Got mine at TSC .Thanks
Edited by ACinSC - 10 Feb 2020 at 12:14pm |
Sugarmaker
Folks,
Had to get out and do something. I asked Matt if he would help plane some lumber. Turns out I was the helper! He brought his D14 and had it belted to the planer in a matter of minutes. He also knew all the moves to make to get this running smoothly. A couple belt changes, some belt dressing, a few adjustments and we were making chips! So we planed some hemlock and then finished a stack of blue spruce that may be used as batten boards. Not my favorite wood to work with, very fuzzy! Regards, Chris Edited by Sugarmaker - 17 Apr 2020 at 6:47pm |
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21451 |
dang those are GREAT pcitures, cept for that white stuff.....arrrrr Shamless !!!
exSW
Orange Level Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
Chris I need one of those planers. Never thought about belting one up.
Learning AC...slowly
Sugarmaker
Yea supposed to be spring! I was about frozen when I got home. Still snowing like crazy! Thanks Shameless!
I think the Steam Show may have two of these planers? I like the hemlock material. Make you almost want to build a building with it. Regards, Chris
Edited by Sugarmaker - 17 Apr 2020 at 6:38pm |
Sugarmaker
Folks,
Some additional shots: Old work horses at rest: The sawmill: Carriage for mill: Now that's a nice hemlock board: And a pile of shavings! Regards, Chris Edited by Sugarmaker - 17 Apr 2020 at 6:50pm |
Dave(inMA)
Orange Level Joined: 12 Sep 2009 Location: Grafton, MA Points: 2395 |
Enjoyed your planing and milling pics, Chris. You and Matt were just having way too much fun! I've got a "portable" bandsaw mill - feels like it's time to get it running again.
WC, CA, D14, WD45
Sugarmaker
Dave, Folks,
Thanks. This type of work reminds me of when I was a kid. We cut a lot of wood and did a lot of outside chores. Not as much now since we moved off the farm. I have several projects to complete at the local tractor show grounds this spring if I run out of things to do around the house. Regards, Chris
