Early Allis B, Hand Lift |
twelliott1973 ![]() Bronze Level ![]() Joined: 07 Sep 2011 Location: Georgia Points: 11 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Sep 2011 at 4:02pm |
I was wondering if anyone might have a picture available of the rockshaft used on a early handlift model B? I have a 1939 model that has the cultivator frame and lift handle, but does not have the rear lift accessories. I have an Athens Plow that I'd like to hook the B up to, but I'm not sure what I am missing. Any help? Thanks, Tim
Perhaps a better description would be manual lift instead of hand lift.
wjohn ![]() Orange Level ![]() ![]() Joined: 19 Jan 2010 Location: KS Points: 2186 |
Unfortunately I don't have this mounted on a tractor, but you should have two bearing brackets bolted under the seat that hold the rockshaft like below. This is the early hydraulic lift rockshaft with some "add-ons" so don't pay attention to the shaft itself. The right hand hand lift bearing bracket is slightly different from below and will have a little L-shaped keeper that prevents the shaft from rotating - it goes through a hole in the shaft and fits into the bracket. ![]() Now, for the hand lift plow, the rockshaft is just a solid shaft with nothing welded to it. The plow lift rotates around the shaft. It's leaning up from the back in this picture, in front of the utility pole: ![]() Hopefully your setup looks somewhat like mine. Otherwise I'm probably just confusing you. Sorry that I don't have a picture of the brackets and rockshaft on the tractor. Feel free to ask if you need clarification because it's kind of confusing without that picture. I do have a manual for the early B hand lift plow but it's at home and I'm at school.
I also have no idea if this setup is relevant to the Athens disk plow, but I'd enjoy seeing pictures of it if you get the time.
GlenninPA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ashley, PA Points: 5054 |
Athens disc plow is a whole different setup I believe. Perhaps Bill P or Brett Phillips could enlighten you, they are two guys I know have the disc plow setups...
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance. Wise men learn more from fools than fools from the wise. |
Thanks for the feedback. I don't have close up shot of the attach area for the plow, but here are two pictures of the tractor and plow.
and...
wjohn,
That sure is a fine example of the very early B plow!
Glenn
TexasAllis ![]() Silver Level ![]() ![]() Joined: 14 Sep 2009 Location: Texas Points: 396 |
My dad always told me the disk plows pulled harder than moldboard types any truth to that?
Ken in Texas ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
You took the words right out of my mouth MR Early B Glenn. Them's the kind we can only dream about.
Not sure about the comparison in pulling. My grandad used the disk plow behind a CA, but later replaced it with a bottom plow. He had both the wide "drawbar" used by the C and CA and the narrow "drawbar" used by the B. He didn't have a B model tractor when I was around, but as I understand it at some point there was one on the farm. Knowing that the B was rated for a one bottom plow I was worried about its ability to pull the two disk plow. She did good though. She'd turn all the topsoil over, 6 to 8 inches, and even go down into the next layer of earth, red gumbo clay. I set the depth of the plow to stay out of the red clay.
Allis Chalmers B, CA, and WD
BF Avery A Farmall Super C International I4 John Deere H, 420, and 430 |
Neat plow, twelliot! I wish you luck in finding the right rockshaft... somebody on here has to know. I'll do some searching tonight and see if I can dredge any old pictures up. |
RyanTN ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Stewart Co, TN Points: 415 |
Here are some pics of the hydraulic Athens rockshaft set up, sorry I do not have a hand lift pic.
![]() ![]() Edited by RyanTN - 22 Sep 2011 at 7:36pm |
Link to a thread on the old forum, but it's for a hydraulic lift on a C: http://allischalmers.com/forum/forum_view.asp?mid=895328&mtop=1094936&mtext1=&mtext2=&morder= Looking at RyanTN's hydraulic setup, I wonder if the hand lift style rotated on the rockshaft like the early B moldboard plow that I posted a picture of. When you push the lift lever forward, the trunnion (I think that's what it's called, but since my parts book is at home I may be wrong) rotates forward on the rockshaft and lifts up the plow. I just cannot find a picture of the Athens hand lift style for a B! It's giving me a break from my statistics homework though...
BrettPhillips ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Strasburg, VA Points: 808 |
Ryan's picture shows the correct rockshaft. The hand lift has a flat link that attaches to the rockshaft about where the hydraulic cylinder would (just to the left of the depth stop crank in his second pic). The rockshaft is actually the same as the one used for the moldboard plow, but there is an arm that bolts to it for the center lift link to attach to. I have 26" discs on my Athens 2-disc plow, and it can be a handful for my '43 C if the ground is really tight or full of sumac stumps as it was at one plow day I participated in. For the most part though, it is a good match and is a real crowd pleaser at plow days and shows.
That's my intent, to have the B ready to participate in the local plow days. Shows are nice, but people always ask "what was it used for?" Being able to demonstrate the old stuff working just adds so much! Does anyone know of a video showing an Athens Plow in action? |
Not to be a wet blanket, but the later brackets for the "rectangular" drawbar won't work... The offsets are wrong. You need a set that looks like the one on the left in the below picture. It is off the very same version of the plow you have.
I picked one of those up on the way home from NYC last fall. Took it apart in a suit and tie, and put it in my PT Cruiser and brought it home. Deb was a little cranky until I showed her I didn't get the suit dirty.... Who cares about a lousy suit anyway???
When I do things like that, she tells me that she thinks marriage must just be an endurance test... I wonder why? ROFLMAO
So Glenn,
The part on the left, where on the rock shaft, or lift shaft as it is referenced in the Athens manual, would the part attach? Is it at the area of #3 on the attached illustration?
This type of forward brackets were on 2 early Bs in my collection. Anyone know what implement they were designed for?
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6045 |
Hmmm... can't say for absolute certain, but if I were mounting up a WOODS belly-mower, or a belly-blade of some type, or a simple swing-down type cultivator toolbar, that'd be just the thing...
Knowing the type of implements used in your area, I'm guessing maybe a bedder or lister. I need to see if I can scare up a parts manual for them some day, but lately I barely get time to stop and see what folks here on the forum are up to...
Ken, those are for the early plow. At some point they went to a round headed pin, rather than the "L" shaped pin, and lost the little clip, as it was no longer needed. I got some of them too, in my parts piles. Don't have enough pieces to get you a complete very early B plow and still have one for me.... Glenn
Edited by GlenninPA - 23 Sep 2011 at 8:07pm |
#3 references where the hydraulic cylinder would attach, OR, where the linkage strap from the manual lift mechanism would attach.
My reference to the drawbar attaching brackets was meant to point out to wjohn that his later brackets won't work with his plow drawbar, he needs to find a correct set. Sorry for the thread hijack..... Edited by GlenninPA - 23 Sep 2011 at 8:12pm |
Yeah, sorry. That would be my fault for getting off-topic. I'll start another thread, especially since it's obvious that the hand lift is different for AC and Athens plows.
oldironguy ![]() Silver Level ![]() Joined: 01 Oct 2010 Location: Shoreview, Minn Points: 370 |
I'm not sure if this is what you need. I received it with some Allis G purchases and don't have a use for it. I'm in Minnesota.
Dick
Hmmm... is this the 'correct' setup for a '38 hand-start B? If so, and someone else (like Georgia Tim) hasn't already approached you for it, I would certainly negotiate a deal to take it off your hands...
I have a VHS video that has "Plowing For Profit" in it. There is a C with a disc plow in that one. IIRC Swinford's book tells that tractors normally pulled the same number of discs as plow bottoms, but the discs didn't cut as wide as a bottom.
The rockshaft from Minn is off a C.
What's the identifying characteristics, Ken??
