D19 Allis hyd ? on using jd 7000 planter |
Post Reply |
Matt (NEIA)
Bronze Level Joined: 20 Sep 2009 Location: Butler Co. IA Points: 168 |
Posted: 23 Jan 2022 at 1:27pm |
Wondering if the factory hrdrolics on a D19 are high pressure like a wd or are lower more modern? Looking at getting one to pull my 4 row jd 7000 series planter. I don't have my jd planter manual at present but seems it requires 2400 psi dual acting remote. Thanks for the help.
1955 WD-45 with factory PS
1963D17
Bronze Level Joined: 05 Jun 2021 Location: Alvord, Iowa Points: 81 |
I can't answer for a D19 but I thought I would pull my IH grain drill with my D17 one year. The grain drill has hyd lift and markers. A sequence valve operates the markers. Two rounds of that was enough. Slower than death. A 7000 planter has cylinders in the tube that have a cable latch system(make sure you pull it out once in a while and oil it). If the D19 is similar to the D17 it will be slow. Not enough volume.
allisdave1954
Bronze Level Joined: 03 Oct 2012 Location: ohio Points: 24 |
i have used my d-19 for years with 7000 planter. works great for me.
Orange Level Access Joined: 12 Sep 2009 Points: 19499 |
D-19 is low pressure (2000-2200 psi) and will work, but poorly. GPM flow is pretty low and when you push the foot clutch in, the hydraulics are dead. A front crankshaft driven pump of 10 to 12 GPM using your existing valves would work pretty good.
FREEDGUY
Orange Level Access Joined: 15 Apr 2017 Location: South West Mich Points: 5391 |
DR., are the hydraulics different on the '19 VRS the 100 series machines ?? We had no issues with a 7000 on the back of a 180 .
The D-19 and 100 series were the same 2,000 to 2,200 psi.
FREEDGUY
Thanks
But I don't recall a front pump on the '19, and the 180 still has hydraulics with the foot clutch depressed ?? Edited by FREEDGUY - 25 Jan 2022 at 6:20pm |
Front pumps on a D-19 have been added to actually make a decent "live" hydraulic system. Everything newer and larger than a D-17 series 4 has "live" hydraulics.
FREEDGUY
Thanks Doc.
What were the pro's/con's of the Allis H/P system vrs the JD L/P system ?
High pressure/low volume systems used less fuel. Low pressure/high volume systems use more fuel and require more expensive/larger diameter cylinders to get the work done. How many days of the tractor use year did the hydraulic system even get used ?? On some Deere 2-bangers they even had a hydraulic disconnect to help on fuel use when no hydraulics were needed. By the early 1960's everyone was attempting to "standardize " hydraulic system pressures so a customer could buy with confidence any brand of tractor and it would work with any brand of implement. So, 2,000 PSI was somewhere in-between the AC 3400 psi system and an M Farmall at 800 psi. AC not having standard equipment 2-way hydraulics was a negative, as was the fact that the hydraulic pump required using the hand clutch.
Lonn
Orange Level Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29773 |
We used to plant with the D19 and 4 row 7000 and it worked good enough for us. The D17 struggled lifting it I think because the hydraulic pump kicked out too easily..... if that was because it was high pressure, I don't know. When Dad used the D17 with the 7000 I was pretty young and he only used it one year I believe and then he rented the neighbor's 175 one year and later he rented a 971 Select-O-Speed Ford from the landlord and then I bought the D19 in 1987 when I graduated high school but we rented the 971 one or two years more after that.
Wink I am a Russian Bot |
FREEDGUY
Thanks for the reply Doc
FREEDGUY
Lonn, or any others "in-the-know", is the "foot print " of the D-19 and a 180 similar (chassis length/turning radius)??
I could not imagine pulling the 4 row narrow 7000 consertill with the '19
Lonn
We pulled a 4 row wide not a narrow but I did pull a 4 row narrow Allis 330 with the 190XT.
Lonn
I'd guess a D19 is slightly longer than a 180 but I couldn't say for sure. A 180 is pretty handy anyhow and just a better all around tractor IMO. I wish I owned a 180 or 185 but I never hated my D19 and I think it is a comfortable tractor for me. Needs a clutch now.
D-19 wheelbase is 103 inches long while a 180/185 is 99 inches. D-19 overall length is 144 inches while a 180/185 is 158 inches. This is a little confusing, but the 3-point hitch draft arms sticking out causes this number to be more while the D-19 was a snap-coupler chassis.
Gary.IL
Bronze Level Joined: 11 Dec 2021 Location: Quincy, IL Points: 13 |
I pulled a 6 row JD 7000 with my D-17 Series IV for years. Never had any issues with hydraulics or power for that matter.
Gary
Quincy, IL D17 Series IV |
I had two neighbors that pulled 8-38" 7000 Deere planters with gas D-17 SIV's. Both tractors had dual wheels and one of the planters had dry fertilizer on it. Both operators said high second gear and 3/4 to full throttle.
FREEDGUY
AWESOME picture Lonn !! we pulled the JD 7000 with the 180 with the monitor on the R/H fender Is that XT a Series 2 ??
Edited by FREEDGUY - 02 Feb 2022 at 5:45pm |
Lonn
FREED, It's a Series III Landhandler. It belongs to one of my brothers. I now pull a 6 row White 5100 with that XT. Keeps the tractor limber vs sitting in his shed for years on end. It is a great tractor.
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7980 |
Definitely better to be used that just parked.....too much goes south on a sitting vehicle of any kind.
Post Reply | |
