D17 Series III Alternator brackets
jkrecek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jkrecek Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series III Alternator brackets
    Posted: 20 Aug 2011 at 1:05pm
Im switching over my D17 Series III from a generator to alternator.  Does anyone know if someone makes/sells the alternator bracket conversion.  The original brackets the generator uses will not work for the alternator.  I am not a good fabricator so I was just wondering if someone makes them.  Thanks...Jason
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2011 at 1:11pm
There are universal alternator brackets being sold but most of the time you still have to redo them for your application.
http://www.alternatorparts.com/Alternator_brackets_1.htm
http://store.alternatorparts.com/alternator-mounting-brackets-tractor-generator-alternator-conversion.aspx
http://antique-tractor-parts.steinertractor.com/tractor/Alternator%20Bracket
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2011 at 2:29pm
Yes, get the alternator brackets off a 170 gas and you will be in business
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2011 at 3:42pm
Use lower alternator brackets from a 170-175. Cut/trim the upper gen bracket so it clears the power steering pump (which a 170-175 doesn't have). Leave cooling fan off of the alternator so it clears the power steering pump belt. You don't need the cooling fan on the alternator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jkrecek Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2011 at 10:30am
Thanks, I will try to track some down..
This page was generated in 0.250 seconds.
