D17 crankshaft oil seals |
djake ![]() Bronze Level ![]() ![]() Joined: 14 Nov 2019 Location: Green Isle, MN Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Dec 2019 at 3:39pm |
I have a D17 Series 1 with leaky front and rear oil seals. Do I have to pull the engine to change them
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 5394 |
djake,
My opinion would be, Yes, Its the right way to do this job correctly. You will need to do a couple other things while your in there too! At least that's how it works for most of us.
Welcome to the forum! Regards, Chris |
D17 1958 (NFE), WD45 1954 (NFE), WD 1952 (NFE), WD 1950 (WFE), Ford Jubilee, IH TD6 Many IH Cub Cadets
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 5700 |
Yes it has to come out for the rear seal. MACK
SteveM C/IL ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 5062 |
You have to pull rear main cap to replace seal if you do it right. Don't leave the F gaskets out when going back together....
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 2469 |
Before you attempt the change, watch Don Bradley's video.
DrAllis ![]() Orange Level ![]() Joined: 12 Sep 2009 Points: 11155 |
It has been my experience that on an old Pre-full flow oil filter D-17 gas engine, when they are leaking at the rear and front seals, 50% of the time they need the crankshaft reground undersized and new main bearings to tighten things up.
