D-15 loud noise in 4th gear |
Austin1945 ![]() Bronze Level ![]() ![]() Joined: 08 Sep 2015 Location: Joliet Il Points: 14 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Jul 2019 at 1:34pm |
I'm looking to purchase a D-15 Series II from a neighbor. It runs out perfect except a very loud whine noise coming from the rear end when driven in fourth gear. All other gears are good with no issues. It doesn't sound like a bearing, more like the bull gear on right side. Has anyone else experienced such an issue and ideas how to fix it? Thanks
TimNearFortWorth ![]() Orange Level ![]() ![]() Joined: 12 Dec 2009 Points: 2014 |
Pretty normal for any D15 to have a howl when run at speed in fourth, have a number of 15's and it'll get your attention when run in 4th if you have not done it for a while.
Still a good idea to check fluid in finals . . . .
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5189 |
Our series II has always done that since it was new. But as said above check your trans and bull gear levels.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24572 |
I had to replace a bearing in the bull gear of 'Troy', D-14 #1. Replacing it was easy... mopping up the oil wasn't fun though OR the loaded tire.... Jay
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 53849 |
The howl comes from the final drives, most of the time, drop the pans, and inspect, at least change the fluid...
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8567 |
Bad brg's on bull pinion shaft on my 45 made it noisey in 4th
Macon Rounds ![]() Orange Level ![]() ![]() Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2228 |
i had one with a BAD pinion gear......
You don't wanna tackle that job......
