D15 - Engine Bogs Down |
Post Reply |
John-Paul
Bronze Level Joined: 24 May 2019 Location: Kettle Falls Points: 65 |
Posted: 01 Jul 2022 at 8:30am |
I have been using the tractor regularly all this year – grading, front-loader work and cutting - and I believe that it has been running as strong as ever. Last weekend while using the front-loader it started to bog down while scooping up wood chips from a huge pile, and then eventually it started to bog down while I released the clutch to move after a dead stop. I thought it could be a fuel line blockage. It was behaving similarly, I thought, to a previous fuel line block. Sure enough, I found a few strips of gooey silicone strips in the bottom of the tank (from the previous owner’s repair attempt to seal up the gas gauge) and a decent sized chunk of the stuff wedged into the fuel channel orifice of the sediment bowl – the part that screws into the bottom of the tank. I started it all back up and it seemed to run quite smoothly during a 15 minute warm-up. I thought problem solved. Next – I put the rotary cutter on. With the PTO engaged, as I released the clutch to get going, it cut out pretty quickly. (The power director is in the low gears.) I was able to coax it to do a few strips of cutting with decent power, but at the slightest uphill grade or thick grass/weeds, it would begin to die out again. If I pushed in the clutch while it was cutting out, it will regain power. Finally, as I went to park it and was maneuvering it around, it just cut out while on hard, level gravel. I am glad to have cleaned out the fuel line like I did, but I still have, probably, the same issue. As a side note, and I don't know if this is related, but the battery has been dead the past week or so, seemingly coinciding to all of this. I have had to jump it the last couple times to start it. I put the charger on the battery last night. I don't think it is either charging or holding a charge. Help! If you need more info or clarification, please ask. I thank you! Edited by John-Paul - 01 Jul 2022 at 9:40am |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77210 |
you have a distributor ignition so it needs a battery to develop a spark at the plug. A LOW battery would be OK, if it was charging... If the battery is almost dead and the charger is not working, that could be a problem...
I believe your tractor is POSITIVE GROUND 12 volt... Did you have the charger leads on the right terminals ? If you try to charge backward, that might effect the battery. I would put in a battery that is fully charged and test.... If it still has the problem, then possibly rebuild the carb again, cleaning out anything that is left.... last, fix the charge system to eliminate future problems.
Edited by steve(ill) - 01 Jul 2022 at 4:47pm |
tbran
Orange Level Joined: 14 Sep 2009 Location: Paris Tn Points: 3208 |
make a way to have a ez on / off rubber line to the carb. When it starts to bog you can pull on the choke or after setting bakes hand clutch in neutral and trans in neutral - pull off the line to the carb. IF it immediately dies or you see no fuel coming out of the tank - presto - restriction somewhere. I f it continues to run ( feeding off the fuel in the bowl) ant there is a good stream of fuel flow - you have a timing or ignition issue as suggested. Seldom though will an ignition cause a 'bogging' w/o missing or backfiring unless there is a severe timing issue.
John-Paul
Thank you!
Post Reply | |
