D15 diesel main bearings, HELP |
Post Reply |
Acdiesel
Orange Level Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2503 |
Posted: 06 Jul 2020 at 5:13pm |
No one can seem to find me a main bearing set for a d15 diesel engine they need to be .020 over. If anybody has any leads on a set that would be great.
Thanks, Dan I think the 262 diesel takes the same bearings, just would have two extra. |
D19 diesel,D17 diesel SER.3 D14 NF,D14 WF, D15 SER.II wf
D15 SER.2 DIESEL,D15 ser.II nf D12 SER.I, D10 Ser.II 2-720'S Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
Larry in NC
Orange Level Joined: 09 Feb 2016 Location: NC Points: 1041 |
Just Googled and Yesterdays Tractors has them.
Acdiesel
yep,called them they don't stock them and there supplier told them that there no longer available in .020"
only std. and .010" Edited by Acdiesel - 06 Jul 2020 at 9:42pm |
TramwayGuy
Orange Level Access Joined: 19 Jan 2010 Location: Northern NY Points: 11204 |
Wouldn’t they be the same as D17 Diesel? Just fewer of them?
DonDittmar
Orange Level Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2476 |
Correct. I ran into this when I redid my 15D. Ordered a set for a 262 and just had some left over. D17D, D19 gas, and D19D would all take the same main set as the 15D, you will just have some extras.
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
Fred in Pa
Orange Level Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9100 |
Call me at 717-634-4398
nonetheless ,still dead. If all else fails ,Read all that is PRINTED. Just because you do not have the tools for job , it dose not make it a bad design. |
Pfouts Family Farm
Bronze Level Joined: 05 Dec 2018 Location: Hiram, Ohio Points: 161 |
If you have not found anything, I should have a set. If you need them, call me 33O 569 7O37.
Acdiesel
Lord willing believe I have found a set if they don't show up I will be giving you a Call.
thanks for your reply. Dan
Acdiesel
Thanks Mark Pfouts for getting me the main bearings.
Fred the bearings I ordered from my local A&I called Thursday and said the bearing set was in,what they had for me was a big sprocket. They called A&I they said that whomever ordered the sprocket most likely got the bearing set, they told me I could keep the sprocket, because they didn't want it. There was no part numbers on the sprocket so they couldn't trace it back to the original purchaser to see if they had the bearings. |
Fred in Pa
Makes you wonder how they sold the sprocket to someone if they have no # .
Acdiesel
Yep, my buddy in parts calls the guy to the front parts counter that opens and sorts the in comming parts and asked where the rest of the parts are for A&I
He said that the only thing there was the sprocket and the pick ticket that was for the bearing set, no sticker or part number stamped on the sprocket any where. So those bearings will most likely go in the trash, just like that sprocket because. He was throwing in the scrap pile A&I didnt want it back. |
Fred in Pa
Seen this before from suppliers, no one ordered a sprocket ,it was just in the bin where the bearing's where to be ,parts puller just grabbed the box and that's what you got . Its not their job to know what the part is they pulling ,they just pull parts numbers that are marked on bins .
Post Reply | |
