confuse with coil polarity WD45 |
Post Reply |
sunsation288
Bronze Level Joined: 02 Dec 2022 Location: quebec Points: 26 |
Posted: 30 Jan 2023 at 10:38am |
hello all , i have remove my coil on my WD45 for painting purpose , and i didn't take care of polarity on my coil ? , i know i have 12 volt negative ground system , but i have found on the internet this picture ...i am ok if my igniton switch to the positive side of the coil ?
sorry for be time consuming !!! my very best regards christian
Thad in AR.
Orange Level Access Joined: 12 Sep 2009 Location: Arkansas Points: 9263 |
Yes like the red on the pic. Switch to + side of the coil and - to the distributor on a negative ground system. |
captaindana
Orange Level Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2336 |
Neg Gnd feed points, ign sw feeds + side coil
Blue Skies and Tail Winds
Dana |
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21331 |
'Red' is right, for you... 'Blue' is bad, well it actually will work, but not as good a spark...... You will not damage anything if you miswire the coil. |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77236 |
if you connect it up backwards ( the BLUE photo).. you will have current flowing BACKWARD thru the point and condenser in addition to the coil... not an ideal situation.
MACK
Distributer is the ground just like battery. If battery is pos. ground, coil is pos. grounded to distributer. MACK
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11503 |
Christian, Don't forget, you have a Pertronix electronic ignition I fixed you up in that new Distributor so, from the E.I. in the Distributor, the RED wire goes to the plus (+) side of the coil, and the BLACK wire from the E.I. goes to the Negative (-) side of the Coil. The circuit from the Ignition switch goes to the plus (+) side of the coil with the RED wire from the E.I. I don't want to see you burn out your new E.I. The fellers here don't know you have an E.I. Steve@B&B
sunsation288
thanks all for your help !!!!
sunsation288
yes i know Steve thanks to taking care of me , i just receive my new carburator , and i wish to start my tractor and adjust the carb and after all the fuel side adjustement work well , i will change my distributor E.I. hope my reply made sense ?
Post Reply | |
