Coil spring bottoms out |
3rd generation
Topic: Coil spring bottoms outPosted: 30 Nov 2025 at 12:31pm |
Allis c coil spring with shock. I’m 210lbs and this spring bottoms out. What’s my solution?
Coil over shock absorber to gain more tension or is a newer coil spring stiffer. |
Posted: 21 hours 50 minutes ago at 9:54pm |
A new shock/spring assembly will be better than what you have. That's what coil springs do over time......flatten out. If it has an slot adjustment, move it as far to the rear as possible.
Edited by DrAllis - 21 hours 37 minutes ago at 10:07pm |
Les Kerf
Posted: 13 hours 44 minutes ago at 6:00am |
I put an old air shock on the seat of my 1941 Johnny Popper. I'm about 100 lb heavier than my grandson so we can adjust it to suit our needs.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5180 |
Posted: 4 hours 55 minutes ago at 2:49pm |
Nurtisystem Weight watchers Olesra chips Paleo Pritkin The choices are endless
3rd generation
Posted: 1 hour 26 minutes ago at 6:18pm |
Funny good one. And yet I’m considered thin by coworkers at 6’2” . I’m going to try a small coil spring rated at 130lbs. just behind the fulcrum along with the original under seat before buying a new large coil spring and spring over shock. I’d prefer this if it works as my wife (120lbs) will use it to mow at times. Take out the small spring for her and vice versa.
