Clearing Land
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: Clearing Land
    Posted: 20 Oct 2025 at 8:05pm
Son-in-law clearing land to open up a new gravel pit using his HD5G with the ripper I installed for him.
darrel in ND View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2025 at 6:23am
AWESOME!!!
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2025 at 9:09am
This ripper was originally for a Case 1050 machine, we estimate it to weigh ~2000 lbs so it should provide adequate counterweight for the loader. Son-in-law purchased the proper ripper mount for the HD5G from General Gear in Boise, Idaho, he also got the canopy from them.
I fabricated the ripper drawbar assembly to tie the ripper mounting plate to the drawbar pull point under the machine, and then fabricated the cylinder mount on the ripper (the cylinder came with the HD5G mounting plate). I made a 1/2 scale cardboard cutout to test the geometry of the linkage to ensure adequate lift and drop dimensions.
I modified the canopy to fit this machine and built the mounts for it; this definitely paid off because SIL tested it when a tree he was pushing came backward and would have conked him on the noggin without the canopy there for protection.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2025 at 11:27am
Pushing brush is a dangerous task. You have to watch for stuff "loading up" getting ready to come flying your way. Would be even better if you could have structure going fwd from cab and down to nose.
Tenn allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tenn allis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2025 at 7:27am
Might want to think about putting expanded metal all around that operator area except for the very front like said you or someone else pushing brush it’s very dangerous
I’m running a D7 with a KG blade and can’t say how many times that metal around the operator area has saved me from injury
After I cut the area we’re clearing my wife and I will put the root rake on to pile the brush and trees and if there’s still leaves on what your piling it’s very hard to see if something is being stressed that might spring back and injure someone
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2025 at 9:11am
That looks handy as heck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2025 at 9:22am
Indeed it is Big smile
That is one bodacious brush blade, the previous owner built it and then used it to clear his homesite, outbuilding sites, etc. and then it mostly sat for 30+ years.
We will be putting the loader bucket on soon and hope to haul some gravel before the snow flies.
Post Options Post Options   Thanks (2) Thanks(2)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2025 at 1:38pm
Finally getting down to business Smile
Eric B View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2025 at 3:25pm
Excellent counterweight for that loader, they can be very tipsy otherwise, a full bucket of gravel is very heavy.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2025 at 5:06pm
Nice to see those old Ford trucks still on the job, doing what they were made for!
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2025 at 9:37pm
with the single grouser pads your track is going to suffer more wear when turning tp load . My 5G is using standard loader pads and I welded on rebar to forward and rear  pad crossbar (pad) several years back and it still is holding up great .
 Bought my machine in 1972 and still is a working machine on 2nd set of sprockets and 2nd set of track . 2 rebuilds on 2-71 - 1 rebuilt head , 1 crank grind , now running a metallic main clutch disc and metallic HD10 steering clutches 40 + years of work with machine , lot of basements dug and lot of sand and fill loaded from my pit .
 My 66 White Tandem with 10/12 yard box is low as no sub-frame that the HD5G can load it easily . But later I found my AC 715B TLB is faster loading trucks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 19 minutes ago at 1:47pm
Originally posted by Coke-in-MN Coke-in-MN wrote:
with the single grouser pads your track is going to suffer more wear when turning tp load ...
Yup.
With that in mind, my Son-in-law pushes up a big pile of material and then positions the loader such that he only goes straight into the pile to scoop up a bucket load, then backs up. We then pull ahead with the truck, he scoots ahead to dump into the truck, the truck then pulls ahead so he can scoop up another bucket, we back the truck under the bucket and he dumps the second scoop. This fills these little F-350's as heavy as we care to be loaded so we then go dump and come back for another round.
As you may guess, this isn't exactly your modern, high production operation Wink But my Daughter is finally getting her muddy drive way fixed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 9 minutes ago at 3:57pm
I fully support the rebar idea that Coke mentions. I did this (made up a jig) to a Cat 931 wide pad machine. The undercarriage shop mocked my idea but 15 years later pads and bars were still in great shape. The owner of the rebar outlet told me to get 'weldable rebar', I had never heard that term before because it seems that any rebar will take a weld. To do this 'rebar addition' to wide grouser pads is a good idea because of the increased width, the pads tend to become slightly rounded after years of use, the extra bar gives good re-enforcement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 2 minutes ago at 8:04pm
Once the gravel is dumped we need to spread it out.
