Carburetor flooding
dfh9036 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfh9036 Quote  Post ReplyReply Direct Link To This Post Topic: Carburetor flooding
    Posted: 07 Dec 2020 at 8:37pm
I just finished the restoration on my D15 Series II and I am having a problem with the carburetor flooding. I rebuilt the carburetor and replaced the fuel line and sediment bowl. The problem is that I am getting a rather large amount of gasoline coming out of the carburetor by the choke shaft and flooding up into the manifold. When I remove the bowl plug gasoline pours out as well. It is blowing gasoline out the muffler when it does start, which is difficult. Any idea of what the cause may be? Thanks.
Sandman24 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandman24 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2020 at 8:50pm
I’m not familiar with that carb but sounds like the float maybe stuck or not adjusted properly
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfh9036 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2020 at 8:55pm
Thanks for the email. Forgot to mention that it is a Marvel-Schreiber carburetor.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2020 at 9:06pm
Needle valve leaking. Seat not tight enough , Debra in seat, bad Needle valve and seat, float full of gas, float dragging on inside of carburetor , or improper adjusted .               MACK
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2020 at 8:09pm
Air filter still attached?  Perhaps it is constricted?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfh9036 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2020 at 10:53pm
Checked air filter and connections. All good and no restrictions. Thanks for the thought.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2020 at 6:24am
gee Mack listed all the ones I've ever seen.....(and had, sigh)...
 teardown the carb...if the float's 'heavy' or sloshes !, it's got gas inside.pinhole leak.easy fix...buy another $$$ float, easier fix, drain all gas from float,buff with 400-1000g paper,flux/solder the pinhole. I used propane torch, lightly, to find one pinhole. gas vapour spewed out of it like  volcano smoke.
I'd also clean the carb ,again (spray brake cleaner) and clean white cloth, as ANY buildup of 'varnish' can make needlevalve sticky.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfh9036 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2020 at 6:58am
Thanks for the input. I will take your advice and go through the carburetor with a fine tooth comb.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2020 at 7:34am
dfh,
 We need some pictures. Leaking spuing gas on a restored tractor not good!
Also on most all of mine I have a habit of shutting the gas off each time I shut it off for the day. Was taught that from my Dad when these tractors were only several years old. Seems they had this issue even back then. All the advice given is on the mark. Something is not correct and the float is not lifting to shut the needle valve or the needle valve seat is not closing.
Yes take it apart take some pictures, do a little research. put it back together and try it.
Float function and needle valve seat are the things that shut off or let gas into the bowl. Looks those over very close. Floats can get bent and out or position too.
Edited by Sugarmaker - 09 Dec 2020 at 7:34am
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2020 at 7:37am
Instead of a torch, I would use an electric heat gun, or my wife's hair dryer, to find the hole and get the gas out.
Dusty
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2020 at 10:48am
Did you adjust the float?  Most likely problem.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2020 at 6:15am
If the float valve is seating/sealing properly no gas can get into the carburetor. You have to start there. A small speck of rust or carbon can lodge and hold it from sealing.  Then you can move to other possible causes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfh9036 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2020 at 6:30am
Thanks for all the input. I am planning on working on the carburetor this weekend and hopefully getting to the root of the problem.
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2020 at 11:22am
The quality of new rebuild kits is suspect..new seats don't....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2020 at 11:48am
Sounds to me like a little chunk of dirt or debris is stuck to the needle valve. These valves make a great seal with that Nitril seal, but if a piece of debris comes into the Carburetor, it'll stick to that valve like fly paper.  When you remove your Carburetor, remove the 90 degree inlet elbow and run a bore brush down that inlet cavity. A lot of rust and debris gets caught in those incoming threads  over the years that aren't used and also debris gets trapped at the rear of the inlet cavity. Then, on occasions, lets loose from incoming fuel and gets caught in the needle valve hanging it up and causing a intermitant flooding situation. Whenever I do a rebuild on a customer's Carburetor, I always make that inlet shiny like its new with a small bore brush on a hand drill. You wouldn't believe the crap that comes outta there!  Good luck! Hope you find the problem....
Steve@B&B
