CA diesel
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Topic: CA diesel
    Posted: 22 Jan 2020 at 10:48am
It’s not just the carb.
You need the following:
   Low-compression pistons;
   ‘Hot’ (Distillate) manifold;
    A way to start on gasoline and switch over to kerosene(or perhaps diesel) after running to heat up. This usually involves an extra tank to hold gasoline and a valve.
This will gain you really nothing except a pat on the back. And at a big loss in HP.
Others may disagree.
Zinan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zinan Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 10:54am
Ok thanks             i was just wondering about it     guess ill stick with gas lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 2:14pm
Stick to gasoline!
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 2:36pm
Good luck on ever finding the right manifold, good tank, and all of the necessary parts, as they are all junk by now!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 3:03pm
Probably easier to bodge a VW rabbit diesel onto it.......
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 3:20pm
Wow , was this an AC option ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 6:12pm
A CA could be had as a Kerosene version. I have a NOS early type manifold.  The carburetor would only need the jets changed. I have 1 New started tank from a batch I had made years ago. The heat shield I've never seen. I made one for my puller that runs on E85.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zinan Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 7:56pm
ahh ok    thx          my dad and i were wondering if it would be possible for no reason at all lol   so i made an acct for something that doesn't matter lol im crazy
Kiwi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 9:57pm
how about a P3 Perkins diesel some of the English b had these engine fitted and Perkins did  a conversion kit for the Allis B
Tractors Allis EB,two C,diesel G
