CA Brake Rod Removal
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: CA Brake Rod Removal
    Posted: 17 Sep 2018 at 11:19am
and Install
My brake rods were put on the wrong sides.  In trying to get the adjustable one off the right side I broke it.  I have a new one that I picked up at Hutch an want to put it on the left side where it belongs.
My problem?    I'm glad you asked! Clap
What is the easiest way to get them on and off without tearing everything apart.
Is it easiest to take these off? Question
2    70225240    1    SUPPORT ASY., guard, R.H.
6    70225238    1    SUPPORT ASY., guard, L.H.
Thanks!
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2018 at 4:28pm
Ted, cutting touch. ->
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2018 at 6:43pm
pumpkinman View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote pumpkinman Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2018 at 7:57pm
looeen adj screw  take pin out of pedel end support goose up use two lg, screw drivers priy them apart
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 6:33am
THANKS Kent!!  I used a couple of pry bars and got it done. Clap
Now the next hard part is that the RIGHT side pedal WILL NOT come off.  The retaining nut and pointed screw came out really easily, but the pedal is SOLID on the shaft.  I've tried heat and pounding to try and get it off, with NO luck.  What a PITA!! Angry
Thanks to Alex09(WI) who is sending me a new pedal and I'm going to cut the old one off.  Unless somebody knows some kind of a trick to do this?
