Unofficial Allis Homepage
Allis Chalmers WD45 Diesel project
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 10:33pm
How hot does a d19 diesel run at for temperature? Got the head off and looked in where the thermostat is a suppose to be And there wasn’t any in there, so trying to figure out how hot to go with.
              Thanks!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2020 at 7:42am
How hard is it to get the timing cover off?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2020 at 6:40pm
Got the timing cover off by Loosening the frame rail and it came right off. Got the head on and the manifolds. Now just waiting on parts.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2020 at 8:00am
Ah, 'Parts Needed' the story of my life!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2020 at 8:26am
Thermostat missing ?? probably because the engine runs hot under load due to a WD45 sized radiator...……...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2020 at 11:51am
Had it running before I tore it apart and driving up a road it would get to about 180 degrees on a 93 degree day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2020 at 11:59am
So, how hot do you think it would get pulling a plow on that same day?? Driving down the road isn't much of a load.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2020 at 2:04pm
Not completely sure but 30 years ago is when my cousin use to use it and he said it never got to hot but that was 30 some years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2020 at 7:01pm
Got the valves all adjusted
JC(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2020 at 11:13pm
Can you find a fan with more blades so you can move more air thru...?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2020 at 8:09am
It has a five blade fan on it right now
This page was generated in 0.093 seconds.
