Allis 190 need speed.
200 allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Topic: Allis 190 need speed.
    Posted: 07 Sep 2022 at 6:21pm
Looking for more wheel speed, currently running 8th gear with cut tires 18.4x38 20" width rims. Not lacking power just need lil more speed. Whether tires 20.8x38 would be better or gears?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2022 at 8:08pm
Change bull gears and bull pinion gears to D-19 and gain 8%.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2022 at 5:55am
42" tires?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2022 at 6:26am
Most that switch to taller tires, don't have the power that they thought they had. Jumping to 42" tire from 38" is more of a ratio change that most think.
 When you get into overdrive gearing, a small ratio change makes a big difference. The   The D19 final drive gears sounds like the low cost option for a gear ratio change.
 Find a pair of 20.8X38 to try first.
brad7066 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brad7066 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2022 at 8:00pm
atlas can make you gears
Gerald10 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald10 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2025 at 7:54pm
Dr allis. Would this work for a 180. Need more speed in 3hi
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2025 at 8:07pm
190 or 190XT or D-19 final drive parts do not interchange with a 180 or 185.
This page was generated in 0.309 seconds.
