8050 Power Shift Problem |
Post Reply |
gl nelson
Bronze Level Joined: 16 Dec 2016 Location: Akron CO Points: 6 |
Posted: 29 Sep 2022 at 7:33pm |
I have an 8050 power shift that sometimes will not shift into 5th. Sometimes it hesitates and then shifts, other times it will not shift into 5th, and sometimes it shifts fine. Once you get it to shift into 5th, it seems to work fine from then on the rest of the day. Just recently I put it in reverse and let the clutch out, and it didn't want to move. About half an hour later I tried reverse again and it worked fine. The linkage adjustment feels fine. I am wondering if it could be something in the valve assembly. Just wondering if anyone has any idea of what might cause this.
Thanks, Gary
MACK
Sounds like a linkage problem inside valve body. A linkage brakes some times, but shifter don't feel right. MACK
gl nelson
The shifter feels like it always has. If you take the valve body off, you can get to that linkage?
MACK
Yes. Don't need to drain oil. MACK
darrel in ND
Orange Level Joined: 22 Nov 2009 Location: Hebron, ND Points: 8567 |
Taking the valve body off is not nearly as bad of a gig as it would seem. I prolonged doing it on my 7060 because I was dreading it. After doing it, it was like, "why didn't we do this a long time ago!"
Darrel |
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8089 |
Anyone have pictures of it with valve body off
gl nelson
Thank you all for the help. After I get done planting wheat I will take it off and see what I find.
Orange Level Access Joined: 12 Sep 2009 Points: 19358 |
You're parking it, right ?? Using a Power Shift when you know there is a problem isn't usually a wise decision.
gl nelson
Yeah it is parked
Post Reply | |
