7GB track loader |
Post Reply |
Larry O F
Bronze Level Joined: 19 Jul 2021 Location: Denver CO Points: 25 |
Posted: 19 Jul 2021 at 4:02pm |
I am in need of parts for my 7gb track loader. The outside bearing for final drive shaft number A23196-0 or Fiat allis number 70629354. Also need the Nut number 70081242 and nut sprocket retaining number 70621241. Can anyone help?
Thank you.
Lazyts
Orange Level Joined: 05 Feb 2012 Location: Manitoba Points: 627 |
The bearing comes up at Minnpar.com. Shows no stock- not sure if it is still available. Might want to check the dismantled listings on Machinery Trader...?
gemdozer
Orange Level Joined: 17 Sep 2009 Points: 940 |
I check tomorrow if am still have these parts and comback to you.
Larry O F
Thank you.
gemdozer
I have 1 used double bearing with 2 cup and have the big nut and have new seal rings and boot spring assambly for HD7.
gemdozer@hotmail.com
Larry O F
I have sent you an email. I am interested in the parts.
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3732 |
7 and 7gb are different machines. make sure you are on the same page here.
Larry O F
I believe the 7hd and 7gb use the same final output shaft components. If that is not correct let me know.
gemdozer
The 7g and 7gb use the same outpout shaft and components only the ring sprocket is different.
Larry O F
What about the 7HD? Is it the same.
CAL(KS)
HD7G is 20 years newer uses double reduction finals and 7GB is an update basically the same. Which machine do you have?
Larry O F
I have a 7gb track loader 1972.
CAL(KS)
ok. no worries then.
Larry O F
Thanks to Hector my 7GB digs again.
Post Reply | |
