This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | ||||
The Forum | Parts and Services | Unofficial Allis Store | Tractor Shows | Serial Numbers |
7GB track loader |
Larry O F ![]() Bronze Level ![]() Joined: 19 Jul 2021 Location: Denver CO Points: 9 |
![]() ![]() ![]() ![]() ![]() Posted: 19 Jul 2021 at 4:02pm |
I am in need of parts for my 7gb track loader. The outside bearing for final drive shaft number A23196-0 or Fiat allis number 70629354. Also need the Nut number 70081242 and nut sprocket retaining number 70621241. Can anyone help?
Thank you.
Lazyts ![]() Orange Level ![]() Joined: 05 Feb 2012 Location: Manitoba Points: 624 |
The bearing comes up at Minnpar.com. Shows no stock- not sure if it is still available. Might want to check the dismantled listings on Machinery Trader...?
gemdozer ![]() Orange Level ![]() Joined: 17 Sep 2009 Points: 835 |
I check tomorrow if am still have these parts and comback to you.
Thank you.
I have 1 used double bearing with 2 cup and have the big nut and have new seal rings and boot spring assambly for HD7.
gemdozer@hotmail.com
I have sent you an email. I am interested in the parts.
CAL(KS) ![]() Orange Level ![]() Joined: 18 Sep 2009 Location: Chapman, KS Points: 3535 |
7 and 7gb are different machines. make sure you are on the same page here.
I believe the 7hd and 7gb use the same final output shaft components. If that is not correct let me know.
The 7g and 7gb use the same outpout shaft and components only the ring sprocket is different.
What about the 7HD? Is it the same.
HD7G is 20 years newer uses double reduction finals and 7GB is an update basically the same. Which machine do you have?
I have a 7gb track loader 1972.
ok. no worries then.
Thanks to Hector my 7GB digs again.
