7000 black belly clutch problems |
Post Reply |
WILLOPS
Bronze Level Joined: 30 Nov 2013 Location: Kentucky Points: 44 |
Posted: 24 Jul 2021 at 5:03pm |
My 7000 has been hard to get into gear since I bought it in January, now that I’m able to use it it has gotten worse, and now it’s to the point where when the pedal is depressed the tractor is still pulling. Where do I test the clutch pressures at, the i&t manual doesn’t show this transmission in the 7000 section and the 7010 sec looks different than what I have. Also the pto is stuck on but the cable is operating the valve as should, not sure if it related but figured I’d let y’all know just in case it is. Thanks for any help.
WILLOPS
I can stop the pto with a board as a break
MACK
If it is a back belly, there is a test port on valve body, right side behind battery. Sounds more like a Marroune belly painted black. Is your PD lever coming back to low when you push clutch to the floor? MACK
WILLOPS
Yes it’s coming back to low, I see at least 3 ports that could be tested on the valve, my sn is 8357 so I’m pretty sure it’s a factory black belly.
Post Reply | |
