670T engine question |
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 659 |
Topic: 670T engine questionPosted: 3 hours 15 minutes ago at 6:22pm |
Did all 670Ts with bosch injectors have the large wrist pins
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
Posted: 2 hours 52 minutes ago at 6:45pm |
1982 was M-100 and Bosch nozzles and big pins in the 8000 series and N-series combines for sure. I think the big pin/3-ring piston thing was the fall of 1980 production?? Still a Roosa pump but Bosch injectors. It would have been at a certain eng s/n break. That's kind of how I remember it.
8070nc
Posted: 1 hour 31 minutes ago at 8:06pm |
Thanks Doc. The reason i ask is I have a 8070 that has the most blowby ive ever seen. Ive found a 670t thats affordable. I know it doesnt have the counterbalanced crank but no harder than ill use the tractor i think itll be fine. Just have to keep the rpm down to 670t level. It has bosch injectors but no injectoin pump is gone and they cut the injection lines. The stubs appear to have been to a m100 pump
1984 80780
