210 puller plowing on you tube |
Post Reply |
Kevin210
Silver Level Joined: 08 Oct 2018 Location: Indiana Points: 356 |
Posted: 21 May 2019 at 10:23pm |
Would anyone happen to know who's tractor it is on you tube posted by
dragined. |
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4762 |
That would be me!
Lonn
Orange Level Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29773 |
Here the link
Wink I am a Russian Bot |
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8167 |
Ed,
Very nice video! Awesome tractor! I need to roll over some earth! Regards, Chris
injpumpEd
That was a long time ago. It's evolved a lot since then lol!
JohnCO
Orange Level Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Ed, Where were you plowing?
Allis Express participant |
injpumpEd
That particular video was outside of Mendota IL on my friends farm.
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4635 |
Ed, 5 more bottoms on that plow and it may have made her grunt some. Lol, sweet 210 you got.
Kevin210
So is that MK II 3700 engine in that 210 and if so how did you deal with the water pump and radiator being on opposite sides.
injpumpEd
Back then it was still the original engine, and I did some cobbling to get water to the innercooler. It has now been switched to a later style block from an N6. I put the 210 water volute and pump on to fit the radiator. To connect the oil cooler water pipe, I cut the 2 different style water pipes in the middle, and connect it with a 2" long piece of straight hose and 4 clamps. Going to the later block allowed me more room to put an A pump on it, since that what our too hot to farm class allows. In this video, it was still a Roosa .450 pump, 4 X .024" injectors, S300 turbo, and a stroked to 5.5" crank for 468 CID. Power wise it played with that 5 bottom, but pulling tires aren't good field tires, and it would just spin if it had any more bottoms. This farm it worked really nice. 2 weeks before this vid, we plowed at the Bergeson farm south of Seneca, and that ground was much harder pulling.
exSW
Orange Level Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
Is the stroked crank still AC or did you use q 466 crank?
injpumpEd
AC crank welded and offset ground.
AC7060IL
Orange Level Joined: 19 Aug 2012 Location: central IL Points: 3197 |
Ed, thanks for your AC 210 plowing video.
So it sounds like your N6’s stroked 426 (468) engine is comparable to a better smaller block version of an AC 516 (4.4375”x5.5625”)? Any idea what your 468 has for hp? Edited by AC7060IL - 23 May 2019 at 3:12pm |
injpumpEd
200hp!
Allisplumber
Bronze Level Joined: 04 Jan 2016 Location: Wisconsin Points: 76 |
I think you forgot about the 1 in front of that 200 !
injpumpEd
long ways from 1200. Was around 400 at the time this vid was done back in 2010. It's over 600 now, but needs to be 750! maybe this year's tweaks will get it there!
exSW
https://m.youtube.com/watch?v=TJJ1ZdN22NQI think this one is more impressive same tractor I believe.
Edited by exSW - 23 May 2019 at 3:16pm |
injpumpEd
That was even before we plowed with it. That was a lot of fun pulling equipment with a hot pulling tractor lol! I've forgotten about all those old vids we did. So much easier to load to FB now.
Post Reply | |
