200 allis |
Post Reply |
prbean
Silver Level Joined: 03 May 2017 Location: Washington, In. Points: 59 |
Posted: 13 Jun 2019 at 4:51pm |
Finally removed the Starter and having it repaired ! dead short a draining the battery a broken + post! On the starter We will see.
prbean
update my 200 Allis should have back from the repair shop by Tues. so he though he said there was a dead short in the poss. post! I hope this will solve the problems with charging He said that the brushes looked surprising good for the age of the tractor 45 yrs old |
MACK
What brand starter? MACK
prbean
I don't no no tag on the starter original I assume
Orange Level Access Joined: 12 Sep 2009 Points: 19499 |
200 tractors came with Delco or Lucas brand starters. Older 200's usually the Delco (which is very heavy and smashes your hands when you remove it) and later models had the Lucas (which was smaller, lighter and poorer quality).
prbean
This very heavy Two of us (my son and me to get out) so from info Dr. I would say it is a Delco not a Lucas but the re builder will know he de not act like it was a problem to get the field replaced and repaired cleaned up! This a 1973 or 74 model I'll keep you all posted PB
MACK
Sounds like a Delco. If it was a Lucas, I would tell you to replace it. MACk
Ky.Allis
Orange Level Joined: 31 Jan 2010 Location: Kentucky Points: 963 |
Why does everyone dislike the Lucas starter? My 200 has a Lucas and in 45 years it has had one rebuild. It seems to crank the engine faster than the Delco on a 185 we bought new in 1972. I will admit my 200 is the easiest starting tractor I have ever seen and requires very little cranking.
Then, someone overhauled your 200 one time and installed 16 to 1 compression pistons in it. Factory was 15 to 1 and they started fair at best, not good. Lucas starters were NOT as rugged as a Delco and 15 to 1 pistons didn't help that a bit.
prbean
Mine has always been hard to start especially when it a little colder or when it hadn't been stated in a while without the help of a little help from starting!
JayIN
Orange Level Joined: 18 Dec 2009 Location: SE/IN Points: 1982 |
Lucas Electric---- the Prince of Darkness! Ask anyone who ever worked on British cars or motorcycles.
prbean
Starter installed still won't start ! Delco starter ! Wiring diagram would help!
Still won't START ?? or still won't CRANK ?? there is a huge difference.
prbean
Does nothing still looking to see what I left off ! Thank you Dr.
prbean
Wish I had a picture before I took it apart! Cranking is another issue. Starting fluid away works
calico190xt68
Orange Level Joined: 12 Jan 2017 Location: Frankton, IN Points: 729 |
I assume from your answer that the starter does NOT crank your engine at all. The wiring is pretty simple to put back on a starter and I would have thought that the starter rebuilder would have certainly made sure it turned over before he sent it to you. If it doesn't crank and the wires are correct, then you may have had a bad ground cable from the start or at least a cable that wasn't making good ground? Have you checked the ground cable or cleaned it off and made sure it is making good contact? This happened to me with a non-AC tractor but the starter rebuilder noticed that there was nothing wrong with my starter and clued me in.
80 7010 w/Cab, 67 190XTD Series I w/500 Loader, AC 2000 Plow, AC 4 row Planter, AC 77G Rake, Member Indiana A-C Partners, Member TAC
exSW
Orange Level Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
Have a Lucas in my 7010. All I can say is big new batteries make a world of difference.
White wire from the key switch to the starter push button. 14 GAUGE white wire from the starter push button to the safety switch on the clutch pedal to the starter.
Allisplumber
Bronze Level Joined: 04 Jan 2016 Location: Wisconsin Points: 76 |
Did you check the clutch safety switch, you will not be getting power to the starter if it is bad , bypass the switch and see what happens
MACK
With someone on tractor holding clutch down, jump from battery cable post to small terminal with white wire with screw driver. It should spin engine over. MACK
AC in the DNA!
Bronze Level Joined: 27 Jun 2019 Location: Maryland Points: 1 |
I had a cable go bad right after the T at the air heater relay. Moving the cable during other maintenance opened the circuit. Looked connected but had no continuity. She was a 1 hour diagnose and 3 hr parts chase but I’ve always preferred coincidental breakdowns at the shop over in field ones!
prbean
Starter works fine now! turns the motor over fast! Start the motor good. Still having to start it by jumping across the terminals of the solenoid to start! Still trying to figure out the switch wiring! Thanks to all! Keep trying till I get it.
prbean
Switch wiring problems now. If someone would be kind enough to take picture of the wiring in there service manual it would be greatly appreciated Thanks PB
200 10and20
Orange Level Joined: 20 Jun 2019 Location: Tim Buk Tu Points: 217 |
Look it up in the Agco parts books. It's all there in black and white showing wires and all.
Ky.Allis
Not to be a smart a** but you need to get you an owners manual if you plan on keeping your 200. It has wiring diagram for both open station and cab models along with lots of other helpful info.
prbean
Order shop manual yesterday from Amazon ! Check out Argo parts book helpful but black and white photo!! Thanks Ky Allis for remind Me! PB
Post Reply | |
