1953 CA w/ Snap Coupler |
Page <12 |
| Author | ||
Joined: 11 Sep 2009 Location: illinois Points: 90119 |
Posted: Yesterday at 12:57pm |
I use this site when i find a carb to figure out what tractor it came off of... Not saying its 100% right, but i have not had any problems so far...... Look at the YEAR on the left, then verify the tractor model ---- carb manufacturer --- then carb number
| Sponsored Links | ||
dfwallis
Posted: Yesterday at 1:03pm |
Yup, that's one of the sites where I did some of my research. I used just about every carburetor related site that comes up in the first 50 pages each using dozens of different search terms. I found many sites that contradicted each other in various ways.
Edited by dfwallis - Yesterday at 1:07pm |
1952 CA13092
wjohn
Posted: 18 hours 6 minutes ago at 7:11pm |
I believe the 9705 and 9706 carbs are from the C, not the CA, so they would be older. They have almost completely different sizes in the jets, vents, and venturi compared to the 11141/11142 that was used on the CA. I imagine those "sized" parts needed to be changed for the CA's higher engine RPM and power output.
Edited by wjohn - 18 hours 6 minutes ago at 7:11pm |
wjohn
Posted: 18 hours 5 minutes ago at 7:12pm |
Do you happen to know the serial number of the CA with the MS carb? Curious if it is an earlier one.
dfwallis
Posted: 16 hours 5 minutes ago at 9:12pm |
Mine is CA13092, 1952, TSX486.
Here's everything AGCO has listed: B/IB/ C tractor - Zenith 70206989 CARBURETOR (#0-8561) (Use 70216937) 70208027 CARBURETOR (#0-8691) (Use 70216937) 70211456 CARBURETOR (#0-9636) (Use 70216937) 70211457 CARBURETOR (#0-9635) (Use 70216937) 70211954 CARBURETOR (#0-9804) (Use 70212844) 70211955 CARBURETOR (#0-0805) (Use 70212844) 70212844 CARBURETOR (#0-9706, 0-10697) 70212845 CARBURETOR (#0-9705,0-10698) (Use 70212844) 70216937 CARBURETOR (S-864) (Use 70224641) 70218487 CARBURETOR (#0-10698) (Use 70224641) 70224640 CARBURETOR (#0-10903) (Use 70224641) 70224641 CARBURETOR (#0-10902) -------------------- MS 70222090 * CARBURETOR ASY. (TSX-305) ** CARBURETOR ASY. (TSX-154) (Use 70222090) ------------------------ CA Zenith NOTE: Qty. shown are for both Carburetor No. 70225621 & 70225622 unless otherwise noted. 70225622 CARBURETOR (w/drain cock) (Outline No. O-1142) (Use to replace gasoline carburetor 70225621 w/o drain cock, Outline No. O-11141) (Don't use on Carburetor No. 70225621) ----------------------- MS 70225679 CARBURETOR ASY. (TSX-486) (Use 70251516) Edited by dfwallis - 16 hours 4 minutes ago at 9:13pm |
1952 CA13092
JEDDY82
Joined: 6 hours 39 minutes ago Location: Horseheads, NY Points: 2 |
Posted: 5 hours 36 minutes ago at 7:41am |
I have 2 CA's, one with a MS carb(1953) and one with a Zenith(1955). The tractor with the Zenith runs like a scalded cat. The other I cant seem to get right. I'm planning on swapping to a Zenith if I can't get it figured out soon.
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3175 |
Posted: 5 hours 17 minutes ago at 8:00am |
Check out your carb my CA with the M-S has run perfect for over 20 years that I have owned it.Previous owner I knew well had the tractor for over 20 and don't think he ever touched the carb.On AC tractors and other brands of that era I'll take a M-S over a Zenith
Posted: 3 hours 38 minutes ago at 9:39am |
Jed... what exactly does the CA with the MS carb do that you dont like ??... jet pluggage is a problem if you cant get full throttle.. Governor adjustments can be a problem if there is bad throttle response ... etc.
JEDDY82
Posted: 3 minutes ago at 1:14pm |
It dosent seem to have the same power as the one with the zenith. It runs way hotter will spit and spudder. it has new plugs, wires, cap rotor, points, condenser ive been through the carb a few times. i have replaced the intake gasket, and torqued. the manifold is not warped. I plan on pulling the carb and swapping with the zenith to see if its the issue or something else. not sure what else it could be.
Page <12 |
