1938 Allis Chalmers WC Speed Mantainer Grader! |
Post Reply |
Alanv8
Bronze Level Joined: 15 May 2019 Location: Argentina Points: 19 |
Posted: 15 May 2019 at 11:16am |
Hello everyone! I'm Alan, from Argentina. I've bought an Allis Chalmers Grader yesterday, and i'm wanting to "restore" it to take it back to life. I don't know much about it, cause i didn't have time to read the original plates to see the year of manufacturing and model of it. I took some pictures, so if any of you can give me some advice or info about it, i would be very gratefull!!
Also i'm afraid that some part is missing in the Wayco distributor, does anyone has a photo of a similar one?? i've been looking in the internet but i can't find the same one... Thank you very much in advace!!! Edited by Alanv8 - 07 Jul 2019 at 8:29am |
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3716 |
Built on wc tractor chassis. If the rear wheels are original i would say early 1938 as it is the unstyled version. Did you mean WICO magneto? unless it has a special magneto from south america they are very common here in the usa
Alanv8
edit: The missing cap is something like this?? (i found the photo on ebay) Edited by Alanv8 - 15 May 2019 at 2:14pm |
CAL(KS)
many different 4 cylinder models of magnetos could work as long as the impulse angle and rotation are corrrect. i dont know the specs myself but someone will post here for you. good luck
as far as i know most of the ones here in the usa used Fairbanks Morse Or FM mags
Edited by CAL(KS) - 15 May 2019 at 2:19pm |
tadams(OH)
Orange Level Access Joined: 17 Sep 2009 Location: Jeromesville, O Points: 9551 |
Steve at B&B should be able to help you if parts are available
Alanv8
Hi!! It seem to be a 1938 as you said!!! It has a series A WICO Mag, but as i mentioned, the distributor cap is missing and, i believe, i will never find it here around. has anyone changed the ignition system for something newer? electronic o something like that?? |
Calvin Schmidt
Orange Level Joined: 11 Sep 2009 Location: Ontario Can. Points: 4515 |
You have an Unstyled WC Speed Maintainer. 411 were built in 1938 and 1939 with the majority being the styled version that also has a different and improved grader frame where it mount at the front. Someone has extended the front end. They were replaced by the extended front with a wide front axle WC Speed Patrol that is fairy common. Mine is only one of three unstyled versions that I know about
NomoreJohnDeere
Silver Level Joined: 24 Jul 2017 Location: Missouri Ozarks Points: 308 |
very nice
HD3
Alanv8
Hi Calvin!! thank you for your response!! I didn't noticed that the front end was modified until you mentioned that!!! jeje. I think i will restore it back to it's original length, i like it most...
Here i found a video of a similar road mantainer. Do you have more pictures of this grader model? Up to now, the missing parts are: the hood, the fuel tank, the magneto distributor cap, and the grader blade clamps. Will post some pics later to figure out how they should be, cause the grader blade have more fixing point than the ones that i have seen.
Alanv8
The front plate from the grader in the video says 1C141 , mine says 1C138, and yours Calvin?
Calvin Schmidt
My plate is 1C114. I do have lots of pictures and an owners manual along with advertising and sales brochures. I did not know about the Maintainer at the museum.
Alanv8
Nice!!! Have you ever used it as a graver? I need to make a way/road in quite soft soil, do you think it can make it?
Calvin Schmidt
I have not used the Maintainer. Years ago I had a Speed Patrol which was the model that came after the Speed Maintainer. It had an extended front frame and wide front. I used it until we put down recycled asphalt and then later real pavement. You should have no problems grading dirt as long as you don't make your cut too deep all at once.
Alanv8
Hello everyone!!! Thank you Calvin!!! This week i've started the restoration, in particular with the rear wheels, rims painting and tire change. I built a tool to remove the old tires and assemble the "new" ones. Will post pictures soon!!!
Is this grading blade original from allis chalmers? it's 3 m wide and the grabbing points seem not to be original. Was it modified? |
Alanv8
First Run!!!
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3236 |
that sound of it running sure boost the spirits that is areal neat machine
Alanv8
Ohh yesss!! it sounds wonderful!! 81 years and still running like first day!!! Here you have a video of the first round |
200Tom1
Orange Level Joined: 03 Jun 2019 Location: Iowa Points: 1114 |
That is certainly great.
Alanv8
NomoreJohnDeere
works good in that soil for sure
steer with the brakes? |
HD3
HudCo
real nice
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8166 |
Given some basic attention those old Allis' just keep on working Good job Alan! Beautiful soil your pushing there too!
Regards, Chris
Alanv8
Yes, really difficult to get used to operate it jeje Still got pain in my arms Edited by Alanv8 - 30 Jul 2019 at 7:28pm |
Alanv8
Alanv8
Thank you!! Now i understand why did the previous owner modified the front end. Otherwise the soil would get stuck in the wheel |
Post Reply | |
