190 aluminum rims on the front
brad durst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brad durst Quote  Post ReplyReply Direct Link To This Post Topic: 190 aluminum rims on the front
    Posted: 17 May 2021 at 8:15am
is there a way to get a aluminum rim on the front of my 190. i would prefer to stay with the 6 bolt hub but would change if i have to
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2021 at 8:38am
Oh yeah there's all kinds of aluminum rims out there
Post Options Post Options   Thanks (0) Thanks(0)   Quote brad durst Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2021 at 1:03pm
are there any that will bold right on. if so which ones
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2021 at 6:40pm
Go to Summit and others - they have the bolt patterns on all that -
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2021 at 10:04pm
6 hole gm' pickup rim.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brad durst Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2021 at 2:50pm
is the center section  smaller on the chevy
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2021 at 9:45pm
you can always make the center hole larger if needed' die grinder works well' just mark it to what size you need'
goomer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote goomer Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2021 at 7:00pm
I moved studs in a 1/4 inch to make a 6x5.5 inch bolt pattern. Machined hub center down to fit rim. Chevy truck is 6x5.5
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2021 at 8:53pm
thanking a 6 hole trailer rim will work also.
