Print Page | Close Window
chain links on my ac corn planter
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=172504
Printed Date: 19 Oct 2026 at 7:35am
Topic: chain links on my ac corn planter
Posted By: mike 44
Subject: chain links on my ac corn planter
Date Posted: 02 Jul 2020 at 1:17am
Posted By: mike 44
Date Posted: 02 Jul 2020 at 1:20am
does anyone know how many links are supposed to b in the drive chain on this planter? I broke a link planting sweet corn , didn't have another but got it too work but wasn't planting rite only one side seemed to be dropping corn down. nothing was plugged.. just wondering if the chain might have caused any issues.. im not sure of the model number of the planter... thanks for any help
Posted By: DiyDave
Date Posted: 02 Jul 2020 at 4:45am
Check for missing or sheared drive pins or set screws that may have loosened or sheared the tip off...Wink
Posted By: DennisA (IL)
Date Posted: 02 Jul 2020 at 7:43am
 I agree, there was enough pressure to break a chain so breaking a pin or set screw is highly likely.
Thanks & God Bless
Dennis
Posted By: Tbone95
Date Posted: 02 Jul 2020 at 8:47am
Not entirely certain what the setup looks like, but as for number of links, you're connecting 2 sprockets together with a chain, right? Number of links in the chain is irrelevant. As long as the chain is the correct pitch, stays together and stays on, the number of teeth on the sprockets is what sets the ratio.
Posted By: NICKMI
Date Posted: 02 Jul 2020 at 1:28pm
Take off the seed cans and underneath each is a round gear that is driven By a shaft that the chain you broke is on and on that shaft is a gear with a pin you broke that pin off is why your one unit stopped working something must be binding there are grease zerks under there
Posted By: JoeO(CMO)
Date Posted: 04 Jul 2020 at 6:30pm
Worn pinion gears under the hoppers will jam and break the chain
Posted By: shameless dude
Date Posted: 04 Jul 2020 at 11:42pm
if you set the planter down while stopped, you might have some dirt jammed up in where the seed come out. always drop the planter while moving.
Posted By: Mikez
Date Posted: 05 Jul 2020 at 8:04am
Also i don't think that planter had a model number. Was refured to has rear mounted drill planter
