D15 II power director oil |
Post Reply ![]() |
captaindana ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2557 |
![]() ![]() ![]() ![]() ![]() Posted: 06 May 2012 at 9:54am |
What do y'all use? I'll bet not the 20W the book says. Hytrans?
michaelwis ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Wi Points: 8765 |
Captain .. i drained my D 15 II , actually drained all oil out over the winter , and in the power director , i used Cenex HTB
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60 GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
TimNearFortWorth ![]() Orange Level ![]() ![]() Joined: 12 Dec 2009 Points: 2014 |
Dana, I have used the Tractor Supply version of Universal Tractor Hydraulic Fluid and they tend to carry two brands in most stores; Traveller and Mystic. May leak slightly more around old seals that are already showing a slight leak (thinner fluid) but both of the above work well down here, even with over 70 days above 100F in our area last year. I see recently that TSC now offers a "High Mileage" type of the above, for "older tractors that required straight oil originally" and it is supposed to be a bit thicker viscosity. Whatever you use, make sure it shows "Allis Chalmers 821" on the label where compatibility of other brands are listed. I run Traveller or Mystic in all eight, including three D15II's, the D17IV and the D19D and never had an issue. (the D19D is the unit I brought down from Herkimer that we talked about last year) Tim
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22824 |
The universal hydraulic fluids, or Hytran fluids are a 20 weight oil. Just much better protection for gears and bearings than the old straight 20 weight non-detergent oil.
Post Reply ![]() |
