8550 serial numbers
Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Quote  Post ReplyReply Direct Link To This Post Topic: 8550 serial numbers
    Posted: 11 Jun 2011 at 9:48pm
Should there be any connection (i.e. same number) among the engine serial number, the serial number on the plate on the right side interior cab post and the serial number stamped into the steel plate at the pivot bracket in the hinge area.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2011 at 9:39am
No, they are all separate I believe.
Bruce Nelson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bruce Nelson Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2011 at 9:40am
The engine serial number went on the engine at the engine plant. The cab was made at LaPorte and got a serial number there. These parts were shipped to West Allis, a tractor was built with them and a serial number was stamped on the frame. The numbers would not match in any way.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2011 at 6:55pm
   Which cabs were built at La Porte ? 6000 ? 7000 ? 8000 ?
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2011 at 10:10pm
I think all 6, 7, 8000 series cabs were built at LaPorte.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 10:39pm
I know Crenlo in Rochester MN was building 6000 series cabs at some point. When I worked there they had a catalog in the paint area with photos of products the produced going all the back to the 70's and I remember seeing a picture of the 6000 series cab.
Wink
I am a Russian Bot
