D17 Clutch
gcalent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Topic: D17 Clutch
    Posted: 11 Oct 2010 at 10:36am
Anyone out there ever machine out a D17 flywheel to accept a 12" clutch, like from a 180?
I need to replace the clutch in my puller, I think the late model pad clutch will be fine for now, but while it`s out, just thinking, you know how that gets you in trouble.
Thanks George
Pullin With AC
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 11:50am
Try It, That's how you learn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 12:16pm
I`m not afraid to try but sometimes it`s not nessary to reinvent the wheel either, I will share anything to help someone from maby reuning a part by trial and error. If there are no negative reports I`ll most likely try it, seems doable enough.
Pullin With AC
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 1:23pm
I would think a 11 inch clutch would hold about any hp . Seeing that 11 inch is used in automotive and has plenty of designs from floaters to button disc etc not including numerous pressure plate designs as well
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 2:00pm
I think it`ll hold fine, just thought I`d through it out there and see if it had been tried. i`m probably just going to install a pad type, with a good pressure plate.
mlpankey, do you use a multi dics behind the big 226?
Pullin With AC
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 2:05pm
I havent I need to though . the two button reduced from four for more holding wouldnt hold fourth gear at the pull that bent number three rod. So I have some work to do to say the least . wd has a 10 inch clutch and fly wheel.
Edited by mlpankey - 11 Oct 2010 at 2:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 2:40pm
Going to add some more ponies this winter, have done well this season but having to deal with too many six cylinder now in 4500 and 5500#. Only won by 4" over a Oliver 88 Saturday night, clutch went to slipping in second high, just got lucky. Had to drop back to first high in 5500 and it held.
Pullin With AC
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 2:52pm
you can get several clydesdales fairly easy out of one.
This page was generated in 0.336 seconds.
