Allis B crankshaft pulley
Jcone1025 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcone1025 Quote  Post ReplyReply Direct Link To This Post Topic: Allis B crankshaft pulley
    Posted: 09 Mar 2021 at 10:05pm
I’ve got a 1940 B that I need to swap out the crank pulley. We’re there different styles? Mine has a single 3/8” tapped hole that is supposed to lock onto the keyway. No other provisions for locking down the pulley. I’ve read posts about multiple set screw holes on these pulleys? Is one style better than the other and and are they interchangeable? Thanks everyone. You guys have been a great help.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2021 at 10:20pm
Multipul set screws are short and on top of each other.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcone1025 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2021 at 10:27pm
Did some have more than one set screw threaded hole?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2021 at 8:17am
no, there are two screw on top of each other, inside the same hole.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcone1025 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2021 at 9:13am
Ok thank you. Looks like mine ran loose for a long time and they tried to braze it on. Crank looks ok so let me know if you have a nice hand crank front pulley for my B. Thank you all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcone1025 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2021 at 7:18pm
Found one. Thanks everyone.
This page was generated in 0.223 seconds.
