Cleaning up Gleaner sheet metal
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Topic: Cleaning up Gleaner sheet metal
    Posted: 02 Dec 2020 at 10:58am
Have any of you guys cleaned rust off the galvanized sheet metal of a Gleaner combine...I want to make this one look a little nicer...just wondering what will work the best or advice of what to do....thanks in adavance.
Matt Folkers
FOLKERS RESTORATION
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2020 at 12:54pm
It seems like we used to use steel wool pads once upon a time.  Brillo pads or SOS pads with warm water.  Rinse off with clear water when done removing rust.  If I remember correctly, you needed to then put some type of wax on the metal or it would rust again soon.  But it's been many years ago and my memory might not be quite right.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2020 at 10:29pm
This doesn’t help much with rust, but as far as general appearance, Blue Magic Metal Polish Cream is great. You can get it at places like O’Reilly’s. Rub it on and it’ll make a galvanized Gleaner shine like a mirror. The shine wears off after a couple years if it’s kept inside.
Edited by CrestonM - 02 Dec 2020 at 10:30pm
MattLF9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2020 at 10:41pm
CLR worked for me.
A little CQB never hurt anybody.
groundhog55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote groundhog55 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2020 at 7:18am
If you want to get serious use the acid that truckers use to clean there aluminum , but you have to clear coat it right after or it looks like crap. Did this with an N7 years ago that had set outside before we bought it.  Another farmer close to us heard what I did and did that on a R72, but didn't clear coat and it looked like crap.
