R52 and 800 series Head
bharper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bharper Quote  Post ReplyReply Direct Link To This Post Topic: R52 and 800 series Head
    Posted: 23 Nov 2018 at 7:49pm
Has anyone put a carry air reel on a 800 series head? We finished cutting beans last night. A lot of our beans were drought stressed and very short. I had a hard time getting even feeding. I put a 3 1-2 inch hose behind the sickle and that helped a lot. We were just curious about putting a air reel on it or maby an orbital reel. It’s a 20’ head. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2018 at 8:28pm
I'm sure an air reel would help BUT, at what cost ?? You will use more fuel for sure, along with eventual upkeep of the system.  Years ago I learned if you moved the header auger forward as far as possible and up off the floor 3/4" of an inch, your poor feeding will become much more acceptable. The cost to try it?? A couple of #50 half links in the auger drive chain to allow it to be adjusted fully forward and upwards.  After moving the auger, your current reel needs to be back as far as it can be to just clear the auger.   Changing your 16 tooth auger drive sprocket to one with 2 or 3 less teeth will slow down that monster diameter auger (which is part of the problem) to also improve poor feeding.  I used to grind off the weld on the 16 tooth factory sprocket and weld on a new smaller diameter sprocket to do this. Do these three things first before spending thousands on an air reel.  Also attaching 1/2" lock washers to the auger flighting to "grab" the crop can help in some conditions.  Just drive the split of the lock washer onto the auger flighting and the tight fit keeps it there.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2018 at 9:39pm
I know they are costly but if you are going to run the machine for several more years I think they are good investment but that is your determination. They take a lot of misery out of bean combining.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bharper Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2018 at 10:53pm
I haven’t even priced an air reel yet so I have no idea of the cost. I was planning on calling the local JD dealer Monday and price one as they are a air reel dealer. Closest Gleaner dealer is 100 Miles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2018 at 10:56pm
Pick up and older MacDon???
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2018 at 9:08am
Doc is right on on the header augers - all the books and service always taught down and back as closed as possible - we sent a demo unit out to a customer and he was having issues of crop boiling up behind auger - the adjustment was made up and out and it worked -  in about every condition .  As to speed, for some reason the RPMs, if slowed down or even sped up feeds better.   The problem of most feeding is short crops where the header is  on slightly uneven ground and the reel is too high on one side and the crop bunches - then when the cutter bar comes up the crop bunch is swept into the auger.  Installation of a raised feather sheet on each end is a good asset  as it places the crop closer to the reel .  On most heads we run the reel as far back and as close as possible. On the large flight 800 and up augers the end flighting MUST be cut back to miss the reel arms on each end - then remove and redrill rearward the stop bolt for the reel and move the reel back as close a possible .. IF the reel needs to go forward to pick up down crop it can still be moved.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bharper Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2018 at 9:26pm
Are raised feather sheets available from Agco or are they an aftermarket item? I have my reel back far enough I can hear it hitting the auger a little bit. When you say cut the outer flighting are you meaning cut the height of flighting down or actually removing say a one inch chunk of flighting completely from the auger. I seem to have more of a bunching problem on the right end of the header verses the left. I will try moving the auger forward and up to see if that improves flow. Can this position be used for wheat and oats also? I’m sorry for asking so many questions but I know if everything was set up right on this machine it would really perform.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2018 at 9:30pm
Where I come from, there isn't any oats or wheat. This adjustment works very well for soybeans. If it doesn't work for cereal crops, you just have to adjust it back to where it was.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bharper Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2018 at 7:11am
I got a price back on a 20 foot air reel. After seeing the price I think I will try some of the header adjustments suggested Dr Allis and TBran.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2018 at 7:19am
More than 5K but less than 10K ???
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2018 at 8:30am
I could be wrong but i think I heard a new air reel was around $14,000........ could have been for a larger head though.
Wink
I am a Russian Bot
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2018 at 9:31am
Hmm, Dr., where are there no wheat or oats?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bharper Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2018 at 9:41am
13K for a 20 foot head. I was at a sale about two months ago and a 93’ R52 with a 18’ head brought 12,500 and it was a pretty good combine. I can’t justify 13k for a air reel being a small farmer.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2018 at 10:23am
SE Minnesota wheat and oats are pretty much things of the past. I could get political on who to blame. Let's just say the government pays better for soybeans and corn.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2018 at 3:56pm
As to moving reel back - one must trim the 7" flighting back to about 4" on the end - this will not affect feeding at all  as it is only less than 12 " from each end that has to be shortened .  Just enough to clear the drive eccentrics.
This page was generated in 0.242 seconds.
