CA belt pully driven gear
Wflorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wflorey Quote  Post ReplyReply Direct Link To This Post Topic: CA belt pully driven gear
    Posted: 26 Aug 2017 at 9:17am
Hello all,
I just got a CA and was starting to go throu it, I found that the belt pully driven gear in side PTO housing was wore beyond keeping. Does any one know if that gear in the CA is the same as a C or B? Thank You!
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2017 at 9:54am
hello, and welcome to the forum.lots of good folks on here with good information.the belt pulley gears are different in a ca than whats in the b & c.the ca gear is a 15 tooth gear and the b/c gears are 17 tooth.this is according to agco's books.hope this helps.here's a link to agco's books.  http://www.agcopartsbooks.com/PartsBooksN/Login.aspx?ReturnUrl=%2fPartsBooksN%2fViewer%2fDefault.aspx%3f
