Pros and Cons of corn pickers
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: Pros and Cons of corn pickers
    Posted: 5 hours 20 minutes ago at 6:37pm
Looking to purchase a 2 row mounted corn picker.
Ill be picking less than 5 acres each year....
My disire is to have a D17 gas tractor under a 190 model corn picker....
My second choice would be a D17 with New Idea mounted picker....
What is your thoughts fellas....
dkattau View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dkattau Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 56 minutes ago at 8:01pm
Storage of ear corn is a con if you’re not set up for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 9 minutes ago at 8:48pm
That's not an issue...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 33 minutes ago at 9:24pm
Pick your poison. There would be 10 times (or more) New Idea's to find used parts for. The Allis would have the benefit of stripper plates.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 27 minutes ago at 9:30pm
We had a New Idea mounted on an Oliver 880 when I was growing up.
Later we had a self propelled Case combine, open station!
"In the weeds" always sat the two row pull behind picker. Never knew why it was parked, and especially not used when the Oliver broke the fancy helical gear set first used on the 880 to cut trans whine.
Homesteading or smaller farm I'd try to locate a pull behind picker. Easy to hitch and go.
Mounted pickers are great for "opening a field up" in the outer rows. But those outer rows are eaten by deer and poor yield because of grass and trees. I'd plant a cover mix band around the field and use a pull behind picker.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 3 minutes ago at 10:54pm
Grew up on a single row New Idea picker. I admit the mounted 2 row pickers are neat but I can see where they would be quite noisy and dirty to run. Although compact compared to a pull type, the pull type are easier to work on and don’t tie up a tractor for a length of time. Most that were mounted, stayed on that tractor due to difficulty on mounting and unmounting. Wish dad had went to a 2 row picker but a single row kept us busy unloading a wagon one scoop at a time into the elevator to the corn crib. Good times…gravity wagons were to come years later lol.
This page was generated in 0.039 seconds.
