Print Page | Close Window
175 hydraulic parts
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=187350
Printed Date: 05 May 2025 at 8:52pm
Topic: 175 hydraulic parts
Posted By: Mdguy
Subject: 175 hydraulic parts
Date Posted: 29 Mar 2022 at 8:16pm
Does anyone have a source to get the connector hub(bolts to crankshaft pulley), shaft that runs from hub to pump and the 2-17 tooth sprockets that run the front mounted hydraulic pump on the 175 diesel. Sorry if the terminology isn’t correct.
Posted By: Albert
Date Posted: 29 Mar 2022 at 8:48pm
Alex at A & W tractor If he don't chime in PM me I will get you his number
Albert
Posted By: Alex09(WI)
Date Posted: 29 Mar 2022 at 8:57pm
Sure! Thanks Albert! We have all those front hyd pump drive parts in stock.
A&W Tractor 920-598-1287
www.awtractor.com
A&W TRACTOR 920-598-1287
Posted By: Joe(TX)
There is a hub on ebay. I think the seller is on this forum. he also has the shaft.
https://www.ebay.com/itm/373939315892?hash=item57108524b4:g:OZwAAOSw58tdjuAt" rel="nofollow - Allis Chalmers 170 175 Diesel Tractor Adapter Hub Hydraulic Pump Drive 70256039 | eBay
Surpluscenter.com has chain couplings. Standard 40P couplings have 16 teeth sprockets.
The engine and pump end sprockets have different bores.
Posted By: Joe(TX)
Date Posted: 29 Mar 2022 at 9:07pm
I was too slow
