New to me 190XT (pics finally)
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=170897
Printed Date: 20 Jun 2025 at 8:14am Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: New to me 190XT (pics finally)
Posted By: NDBirdman
Subject: New to me 190XT (pics finally)
Date Posted: 07 May 2020 at 10:06am
This is the 190XT I recently picked up. I don't think I did too bad for $1200. I tell my wife I bought the snowblower for $1200 and they threw in the tractor... LOL The blower is an International 80. Had to do a little work with torch/welder to straighten out the flighting, looked like someone had backed into a large rock or sumpt'n. I changed all fluids/filters, new thermostat, 2 new batteries, wound up having to change the water pump. Now she purrs like a kitten albeit a dirty one. I need to take my pressure sprayer out there and give her a good bath. She's a factory bare-back with a farmer built 3-point system. Couple things I need to figure out on her yet but I'll get there. I have a 14ft disk to give her a good work-out as soon as the ground dries up.... farm looks like a big wet mud hole right now.
------------- 1955 WD45 S#205467, 190XT #6652 DXT
Date Posted: 07 May 2020 at 10:28am
Date Posted: 07 May 2020 at 10:35am
This is on the left above the manifold. Looks like a short spark plug of sorts, the wire for it is laying below it taped over with electrical tape. It goes back to a solenoid behind the engine. Is this some sort of pre-heater? And what is the plug on the side for?
Posted By: jiminnd
Date Posted: 07 May 2020 at 10:36am
Looks like a good buy for that price, not even scrap value.
------------- 1945 C, 1949 WF and WD, 1981 185, 1982 8030, unknown D14(nonrunner)
Posted By: Joe(TX)
Date Posted: 07 May 2020 at 10:58am
The spark plug looking thing is the air pre heater. There is normally a pipe plug in the side unless the is ether injection.
------------- 1970 190XT, 1973 200, 1962 D-19 Diesel, 1979 7010, 1957 WD45, 1950 WD, 1961 D17, Speed Patrol, D14, All crop 66 big bin, 180 diesel, 1970 170 diesel, FP80 forklift. Gleaner A
Posted By: AC7060IL
Date Posted: 07 May 2020 at 11:09am
Great buy! Serial number? Love the early series I bar grilles & arrow decals. Added bonus, it's factory cab should have protected dash/console/battery/seat areas.
Date Posted: 07 May 2020 at 11:28am
Joe(TX) wrote:
The spark plug looking thing is the air pre heater. There is normally a pipe plug in the side unless the is ether injection. |
Thanks! It has the first (?) series ether in the cab, the line is there but is not connected to anything. So I can plumb the ether to the plug and hit the button for a quick shot? That leads me to another question, if that pre-heater is connected/used, then hit the ether button (injecting right at the heat source), would that not make for a big bang (?) in the manifold itself?
Since this is going to be used mainly as a snow blower which system would be best for starting? Our temps Jan/Feb can and does frequently dip well below zero, which system is best for starting at those temps? I will say I don't favor ether after what I saw couple weeks back. That is a 4020 with engine tore down, did a lot of destruction. Guys wife gave the diesel a good dose of ether to start with throttle about half full..... engine did not take it well. I don't want to do this to the 190!
Apologies if my question seems silly. My other diesel tractor has block heaters and glow plugs, it still does not like to be woke up during low temps.
Posted By: jiminnd
Date Posted: 07 May 2020 at 11:33am
do not use the manifold heater and ether together, if I was you I would put some kind of block heater or tank heater for ND winters. My 185 has block heater, will heat up in just a couple hours.
Posted By: JohnColo
Date Posted: 07 May 2020 at 11:36am
First off, I wouldn't worry about explaining it to your wife, more concerned what you will tell the sheriff when the guy who "sold" it for $1,200 reports it as theft! LOL
I would go with the engine pre heat. As long as you have good batteries, it will do the job, of course if you have a plug in engine heater, that is even better.
Oh, is that a MM Jet Star in the background? The one without back feet?
Posted By: DanWi
Date Posted: 07 May 2020 at 1:16pm
Below 0 i would want an engine heater and good batteries and I would also get the glow plug working, I would hate to think about starting that engine ice cold. It seems like when you start them on ether things only seem to get worse, rings start breaking. A guy I know was doing that with a combine till it got so bad. Just thinking out loud but if a person had to rely on a tractor like that to plow snow or feed animals in winter when it gets down to 0 batteries lose cranking power and I have seen some that have mounted batteries on the frame close to the starter. What would happen if you had the 2 originals and wired in 2 more on the frame?
Posted By: Boss Man
Date Posted: 07 May 2020 at 3:47pm
Skip the ether. Its a down hill slope when you use that. Install a block heater and get the manifold heater working.
Date Posted: 07 May 2020 at 6:01pm
Yes sir, it is a 5-star. It needs a rim and all new shoes. We destroyed the rim but that is a different story with it. So far, no luck finding a rim with old shoes, it would be used as a bush hog machine but finding a rim, no luck. The guy would probably let the tractor go as is pretty cheap if someone was interested.
Posted By: Michael V (NM)
Date Posted: 07 May 2020 at 9:45pm
The glow plug is energized by turning the key to what would be normally a start position, hold for 15-20 seconds. The manifold will get hot if its working, you will definitely be able to feel heat if it's working
Ok, I hope it works. As you said this will be a winter time tractor, a block or tank heater would be a good investment, also a building to park in will help also,be great if that could be heated too
Posted By: ac45dave
Date Posted: 07 May 2020 at 10:46pm
Good score for $1200.00 for sure.One heck of a good deal.looks good.
------------- 54 wd-45gas ; 56 wd-45d N/F w/fact p/s ; 63 d-17 sIII N/F gas ; 60 D14 N/F ; 67 d-17 sIV N/F gas ; 63D15 sII W/F; 39rc#667 ; 2021 massey 4710 fwa ; gravely 2 wheel tractors
