Terra Tiger Cone Clutch Rebuild
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Terra Tiger Cone Clutch Rebuild
    Posted: 28 Dec 2015 at 9:49am
Hi guys,
Where could I send my Terra Tiger cone clutches to to have them relined and/or reglued?
Thanks
Terry
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2015 at 10:05am
get ahold of " farmtoybuilder" on the forum, he is kind of the "guru" on TERA-TIGERS.
Edited by ctbowles58 - 28 Dec 2015 at 10:06am
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2015 at 10:58am
We can fix you up Terry! Or if you have a mining type shop that relines clutch and brakes from cranes and such could do them. Takes special adhesive for them. We have a set of relined ones in stock. Exchange your old ones for new would be $150.00 plus $12.00 shipping. We also have new springs and h duty springs for them.
Ron Nelson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron Nelson Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2015 at 9:23am
I had Rick in Mo. reline mine and he did a great job.
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2015 at 2:27pm
       Ditto, on Rick here on the site, if it has to do with clutches or brakes,,,he will do you a great job,,,plus he carries a really sharp pencil,,,,!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2015 at 3:51pm
Common lining material doesn't last long on them. We tried quite a few different types of material on them. And old weak springs allows slippage and wear! You should install new springs when replacing cones. We had a Heavy duty spring made for them also. It stands higher HP engines and No washers are needed on them to increase pressure on cones. Our racing-play one has been running 2 years or so with a modified Kawasaki 30 hp. v twin engine and clutches are still like new.
Ron Eggen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron Eggen Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2015 at 7:34pm
Try Route 6 X 6 .com for info on all terra tiger needs.
This page was generated in 0.258 seconds.
