drawbar for a allis CA
starstepper020 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote starstepper020 Quote  Post ReplyReply Direct Link To This Post Topic: drawbar for a allis CA
    Posted: 16 Feb 2012 at 3:49pm
have an1952 Allis Chalmers CA   Looking for a drawbar--- not sure what it need  -- there is a woods L59 belly mower on it.  looks like a b drawbar would work  but it has to be much wider than a B, their is a mounting pin under the tractor just in front of the rear axles. Looks like a C shaped drawbar which fastens to final drive  would work if allis made one ,  Any help would be appreacated Thanks   Phone 315 668 9804
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 4:42pm
The pin hitch drawbar attaches to the pin under the belly and to the lift arms when they are in the vertical position. You could probably bolt a C drawbar to it but the mower would have to be off. I have had the Woods mower on my CA with the pin hitch drawbr in place after altering the Woods brackets. Sorry I don't have a pic right now. Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote starstepper020 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 5:06pm
thanks  for your input, have a great evening
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 5:24pm
a c drawbar bolts on and works good.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 6:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 6:31pm
Forgot to add my text. This is how I put a hitch on my CA. My factory drawbar would have been in the way for the belt. So I welded two small peices of angle iron to the cross pipe then two pieces to a reciever and just bolted to tractor crossbar. I can use any hitch that I have for my truck, ball, riser, lower, or pin.
Leon B MO
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 6:36pm
You can use the C drawbar with a woods mower.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 7:42pm
  we havve a C DRAWBAR if needed    1-800-254-3116
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 8:07pm
you can use either a CA pin hitch drawbar or a C drawbar with the woods mower mount without any modification. I have one of each they both work fine. My CA also has a loader mounted at the same time. I take the loader arms and rams off during the summer when the mower deck is on.
Post Options Post Options   Thanks (1) Thanks(1)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 8:13pm
I have the universal mount tube like Dicks, works on a B,C or CA. The pin hitch drawbar will not fit unless it is lowered. There are different mounts and maybe one like Leon has would work with the pin hitch drawbar.
Steve(SEMN) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Steve(SEMN) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 8:38pm
We have a non snapcoupler wd drawbar on our CA that is bolted around the horizontal iron piece. Sticks out a bit more but is nice to use as a step to get on tractor.  It had to be modified a bit at the front anchor point.
Edited by Steve(SEMN) - 16 Feb 2012 at 8:45pm
This page was generated in 0.810 seconds.
