Cutting wheat with an Allcrop
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Topic: Cutting wheat with an Allcrop
    Posted: 07 Feb 2012 at 8:55pm
I know it's a long way off, but I thought it might be a good subject for a cold winter night. We will be cutting wheat for the first time this summer and have a couple basic questions and would like to hear your comments.
First if you're going to bale the straw do you cut the wheat just under the head and then run a mower after the combine? Will a 72 and a 90 handle the whole plant and still be able to thresh the wheat clean and not be overloaded? From Utube it looks like most people run with the discharge chute folded up in wheat.
Second how do you open the field? I don't remember much about pull type combines, I've always run self propelled machines. I used the 72 to harvest some replant sobeans, but they were ponds here and there and I could work around them. I know we have to put straw on standing crop the first through.
We have a 72 that we've used before and a 90 that looks to be field ready after greasing and possibly replacing a belt or two just to be safe. In beans with the 72 I set the cylinder speed, fan and chaffer and away we went. It walked through healthy drilled beans and sometimes some grass and weeds and kept the sample clean and didn't put anything out the back (side) I didn't have any additional screens. With the 90 we have what looks like a bean screen but nothing else. Does either combine need a screen for wheat?
We have the manuals for each machine but we're wondering what other tips or tricks can you give us. We put a whopping 7 acres of wheat in just to play with the combines this summer.
AGCO My Allis Gleaner Company
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 9:13pm
If It was me doing this, and some people my think different, I would cut the wheat about  4" off  the ground and  would not use the straw hood /spreader at all. Fold it back and go to town. The straw will be in great shape after a single pass under the cylinder. Thats just me. Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 9:35pm
I believe my father opened our rectangle shaped fields by going around the outside of the field the opposite direction that he would do the rest of the field. Yes you run over a little that first round but it's no big thing. He turned the straw walker up out of the way like ryan said. We baled all our straw and I saw him do it several ways.Sometimes he clipped off the tops and then mowed and raked before baling,other times he cut just above the ground and ran it all through and would bale right behind the combine without raking. I guess he did what the weather allowed him to do.Being dairy farmers the straw was more valuable than the wheat.I am sure the 72 we had did an excellent job of cleaning the wheat even when running all of the crop through.There should be seperate screens for different crops.Also different settings for fan speeds. Manuals should tell what is needed for each crop.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 9:39pm
   Cut it about 3 - 4 inches high, shouldn't need to mow it.
Will a 72 and a 90 handle the whole plant and still be able to thresh the wheat clean and not be overloaded?   Yes.
   If your not going to open with a Self Propelled, You have to run over the wheat for a pass or round, depending how the field is.
I don't remember much about pull type combines, I've always run self propelled machines. I used the 72 to harvest some replant sobeans, but they were ponds here and there and I could work around them. I know we have to put straw on standing crop the first through.   Yes.
We have a 72 that we've used before and a 90 that looks to be field ready after greasing and possibly replacing a belt or two just to be safe. In beans with the 72 I set the cylinder speed, fan and chaffer and away we went. It walked through healthy drilled beans and sometimes some grass and weeds and kept the sample clean and didn't put anything out the back (side) I didn't have any additional screens. With the 90 we have what looks like a bean screen but nothing else. Does either combine need a screen for wheat?  You will have less trash in the bin with the screen, but can do as good as job as a modern combine without one.
http://www.rumelyallis.com
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 9:43pm
Ryan has the right idea .. plus you get the chaff..makes for nicer bedding ....
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 9:49pm
The straw with be in great shape, something these rotary combines cant match. But you wont see me cutting 100+ acres a day with my allcrop 72!!!!!!! Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 12:30am
we always had clover growing and cut at the top of it then baled the windrow. sometimes the clover got too tall and had to run some of it through as well.That was good for a slug or two.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 9:55am
Yes we had about 5 acres or so of replanted soybeans that were still green so we cut around them and left them to mature. When they were ready I thought it would be fun to get the 72 out and use it. We spent half a day (and had a lot of fun) doing what might have been 20 - 30 minutes work with the 2388 CIH. Not to mention the time it took to get ready, there are a LOT of grease zerks on a 72! LOL We kept saying if we had the whole 64 acres to do it would be a long time getting done. As it was the boys were unloading on the go where the rows were long enough.
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 10:00am
When I tried taking the whole straw I got clogged up...maybe I needed to go slower...
I see no purpose of the straw hood unless you have a chopper mounted to it.  Seems to
slow up the straw movement to me...
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 10:06am
How low to cut will depend on the crop and weather. A couple years ago we ran some 75- 80 bpa wheat with our 66 in less than optimum drying weather. In first gear with the WD the combine had all it wanted cutting just low enough to get all the the heads. In the real heavy areas I had to cheat over and take less than a full swath. In a lessor crop or excellent conditions I preferr to cut low enough to eliminate the extra pass clipping the straw myself, others prefer to clip no matter what,  saves some wear and tear on the combine and you cut a little closer to the ground and gain a bit of straw.
Edited by Butch(OH) - 08 Feb 2012 at 10:07am
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 11:18am
Dave, to your screen question... I think they all need a screen for wheat.  We have one wheat screen for the 60 & 66 for sale, but someone will have to tell you if they also fit the 72.  The 90 uses a larger screen for sure.
'41 C w/Woods L503 mower, #3 mower, 2-way plows for C
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 12:22pm
Apples and oranges, but when I grew up on the farm, we had a MM G4 combine.  The straw was worth about as much for bedding as the oats was for chicken feed (didn't grow wheat).  Dad would cut as reasonably close to the ground to maximize the straw without running the sickle bar into the ground (he had cut the 12' head down to 9').  Of course, the spreader was not on and the windrows were then directly baled as fast as possible to avoid them being rained on.
Getting the straw through the G4 was not a problem--------it had its own engine and ground speed was easy to control with the tractor throttle.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 3:08pm
The 60, 66 & 72 have the same size screens.
Robert Mull Georgia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Mull Georgia Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 4:55pm
In the early 60's my Grand father had a 60 with only the two sacker platform (no grain Bin). I rode and tied the sacks. We always had the straw hood up and the grain sack slide up on the first round so that the bushes around the edge of the field would not tear them off. I got slapped quite often in the face and arms on those first rounds. On the second round the Grain Sack Slide and straw hood were lowered into place. The straw hood kept a lot of the dust off of me. It was a must when combining oats. Oats are itchy.
Bolivar Boy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bolivar Boy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 7:30pm
dave. my family bought their first combine in 1959, a used all crop 66, canvas feed, pto drive. fantastic machine. in ohio, most fall drilled wheat was companion planted with grass seed like clover,rye grass and alfalfa. the old gezzers would wait till february of the next year to broadcast the grass seed, with a hand broad caster, if their old grain drill didnt have a grass seeder attachment. the wheat was then ready to thrash the 3rd and 4th weeks of june. we pulled the combine on flat, rolling and hillside grounds with a d14 in 2nd gear high range, sometimes low range if the thistle patch was heavy. by now the grass growth was 4 to 5 inches high so we cut just above it. we always ran  discharge hood down, raked the straw once and baled. in oates, we cut just above the rag weed with discharge hood down and broadcaster in place to rid the straw of itchy dust, hulls and arrant rag weeds. the only time the 66 would choke would have been in a bad weed, thistle infestation within the harvested crop or the harvest crop was above 13% moisture. you could feel the ohio humidity coming back into the straw around 6:30 in the afternoon so you went to the barn until 12:30 or so the next day and repeat.
my first combine in 1988 was a jd 14a that i pulled with the same d14 and a d17d. it was a reliable machine but terribly slow and would choke in a heart beat. its only advantage was that it was lighter and easier to tug around. nothing beats the sound of wheat straw hitting the cylinder of an all crop pulled by a companion orange tractor.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 7:50pm
I posted this story before but I think its interesting to see how times have changed. About a half mile down the road from our farm there lived a elderly bachelor farmer. One field across from his home was every bit of 100+ acres and he combined the whole field by himself with a allcrop 72 and a D17. He would park his small grain truck by the road and combine until it was full. He would shut the tractor off and then drive the grain truck to the local grain elevator in Worden,Il.  Then come back to the field and start all over again. No help at all, just by himself in the summer heat. He passed away about 15 years ago I'd say and the farm was bought by one of the biggest farmers in the area. Last summer when I drove by the same field I saw two of john deeres biggest combines cutting wheat and three tractor trailers being filled up. WOW!! This one old man used to combine that field with a combine that cut 72" at a time and got it done and nowadays it takes two headers on green combines that were 35' wide to do the same field!! Times are a changing indeed. Ryan
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 10:01pm
I had exactly the same experiences, except I was in the Northern Tier of PA, and it was the late 1970's...
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
daughter#1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daughter#1 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 10:24pm
                                       Here are a couple of photos of one of our wheat harvests. This is jim Jrs 40 with the territory rep from KRONE at the controls. There was a lot of kidding about all of the ideas taken from the 40 that will be showing up on krone.lolLOLLOL   Jims 40 did a great job, we had a yard full of onlookers that day, and many pails of wheat taken home for flour.  One year we used the 66 It also did a good job.SmileSmileSmile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 10:48pm
   Kelly, that is a beautiful 40 ! Is she all original ?
Edited by Rfdeere - 08 Feb 2012 at 10:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 11:00pm
That is Jim Palmer jr's 40. It was the model for the show toy for the Orange Spectacular.
Jim has a YouTube video of me operating it at Hutch. It is one of my favorites. It sure is a sweet machine!
Post Options Post Options   Thanks (1) Thanks(1)   Quote daughter#1 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 11:05pm
I believe  that it is.  JimIa can give the whole story on his 40. Its a great running machine. they drove over and went right to work with it. A former neighbor that passed away just a few months ago came to watch it run, his relative had one and he thought that it might be that one. Watching that day he said it brought back many many ac memories. You may have seen him at some time He won many tractor pulls with his d-21, and went to the nationals with it. Deania rembers when he got the first 7040 in the area and took it to a farmers pull and they almost had to drive into town to stop it, The JD men cried.  CryCryCry
Edited by daughter#1 - 08 Feb 2012 at 11:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 11:12pm
   I thought that might be Jim's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 11:17pm
   LOLLOLLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote daughter#1 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2012 at 6:09am
I guess i did not state it clearly in my first  post. It is jim Jrs 40, Jim sr is riding and krone rep is driving.  I do not own a 40. jim and jim are neighbors, That came over to play. I don't have pics of my combines doing it because I'm driving, and am not skilled enough to take pics at the same time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 8:03pm
So does anyone have a wheat screen for a 90 for sale?
Proangler1700 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Proangler1700 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2019 at 4:19pm
Hi, this is a long shot, but do you still have a wheat screen for sale for your Allcrop 60?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2019 at 9:00am
Proangler, I wish I could help, but we sold all of our screens.  Happy 4th of July!
This page was generated in 0.199 seconds.
