Buda injector tester on ebay
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Topic: Buda injector tester on ebay
    Posted: 16 Sep 2011 at 8:38pm
Looks like a real neat piece to use or put on the shelf
http://www.ebay.com/itm/Buda-Hydraulic-Diesel-Nozzle-Tester-Allis-Chalmers-/360393736138?pt=LH_DefaultDomain_0&hash=item53e923ffca
Edited by Bill_MN - 16 Sep 2011 at 8:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2011 at 3:02am
Wonder how that thing works ?
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2011 at 6:36am
You basicly hand pump fuel through the injector. The pressure gauge tells you how much pressure it takes to push fuel through it and if the pressure is low the injector is wore out.
Also you look at the spray patern. I have no experiance but i watched Dad use his many years ago. I'm sure to Diesel guys will correct me if i am wrong.
The universal answer to all questions is yes, how much do you want to spend?
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2011 at 6:34pm
Pretty close on the function Dave. You heck the pressure setting, Spray pattern for worn or dirty nozzle, And to see if it holds a specified pressure.
