D-10 SERIES III GAS TANK |
BV ![]() Silver Level ![]() ![]() Joined: 12 Sep 2009 Location: Bono Arkansas Points: 486 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Oct 2020 at 11:19am |
i'm looking for a good gas tank for a D-10, are all series the same? mine has small pin holes in it, how can this repaired?
Alvin M ![]() Orange Level ![]() Joined: 24 Jun 2018 Location: PA Points: 800 |
Use The Fuel Tank Liner Kit Steiner Has It Plus A lot Of Other Places Northern Has Blue Kote Liner Kit I Did A Lot Of Tanks That Had Pin Holes Stopped Them All Must Use The Kit Not Just The Sealer It Will Not Hold
Eric B ![]() Orange Level ![]() ![]() Joined: 09 Feb 2012 Location: British Columbi Points: 966 |
I used Permatex gas tank repair. Comes as a little sausage, just cut off how much you may need and the knead it together, as the hardener is in the center, then apply on a clean surface. I found it to be excellent, I fixed close to half a dozen pin holes on my "B" tank and it has been perfect for several years.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 4979 |
D-10 and D-12 ranks are very hard to find. A while back PaulB was looking for one for his puller. As far as I know, hew hasn't found one yet.
I cleaned, lined and sealed a WD45 tank several year ago and had good luck. I think the secret is following the directions to the "T" and not taking any shortcuts. If you do find a tank, Paul might be interested in your old tank.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24572 |
Small pinholes ? get rid of paint,shiny it up,rinse tank with soap and water, use 250/500 watt soldering iron...
tbird ![]() Bronze Level ![]() ![]() Joined: 01 Nov 2013 Location: usa Points: 133 |
Used the tank liner kit and it's works great save a little to put it on where out side where it's sits on the saddle strap
justinhamlett ![]() Bronze Level ![]() ![]() Joined: 08 Jan 2020 Location: Lebanon, TN Points: 53 |
What brand of gas tank cleaner and tank liner does everyone recommend?
It's been several years and I'm not sure if they have changed, but I used this one from Eastwood.
Ed (Ont) ![]() Orange Level ![]() ![]() Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1476 |
I have repaired several automotive tanks with jb weld. Works well. Sand and paint next day. Have not had one leak yet.
tractorboy ![]() Silver Level ![]() Joined: 03 Oct 2009 Location: southern Va Points: 474 |
oriellys carrys the red kote brand, around $30. i've done several and a 60 f-100 rusty tank all turned out very good . just follow the directions and don't rush the drying time !!
