Wd45 plow size
mhankins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhankins Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 plow size
    Posted: 15 Mar 2019 at 6:17pm
Will a Wd45 pull a 3 bottom plow in no rock bottom land?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2019 at 6:28pm
I have no idea what your soil is like. Normally, yes, a WD45 was pretty much universally accepted to pull a 3 bottom 14 inch mounted AC plow. Now, I know where there's some bottom ground where a 190XT had all it wanted with 3-16's, so conditions make a difference.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2019 at 6:53pm
We pull 4-14 in gumbo ground .
Plow must be set right and the tractor must be weighted.
Edited by DennisA (IL) - 15 Mar 2019 at 7:13pm
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhankins Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2019 at 7:32pm
Thanks for the replies.
I'm buying a wd45 and didn't want to over load it,but wanted to use it's full potential,too.
 I grew up on a farm,but it's been 50 years,and don't remember a lot about it.
Robert Musgrave View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Musgrave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2019 at 8:32pm
Our WD-45--(Gramp's Tractor) would pull 3-14's in third gear WOT and just walk away.  Most of our ground in NW Ohio was Pewamo Silty Clay loam and Blount Silt Loam.  The WD with a #53 Pick-up plow would sometimes stuggle in 2nd gear, but the We-45 with the semi-mount plow was quite a combination!   R. Musgrave
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2019 at 11:07pm
The WD45 was billed as the "Pull a 4 bottom plow" tractor.
I have and I know others who have pulled a 4-14.  Piece of cake.  I've never see one with a 4-16 on it, so I don't know about that.
GOOD luck on your purchase, you won't go wrong.  I don't think you CAN overload a WD45..Big smile
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2019 at 6:41am
If it won't, its not that hard to drop a bottom.
AaronSEIA
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2019 at 7:21am
Yes, a WD-45 and a 3 bottom plow is a good match.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2019 at 7:30am
And to the original question, you MUST have full fluid in the rear tires to do any serious plow pulling. This fluid will be 900 to maybe 1,000 lbs of weight depending on which size tire you have. Bigger plows may require extra rear wheel weights and some on the front too. Rear tires can't be bald.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhankins Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2019 at 9:02am
I am in North East Arkansas.
 Coming from North west,Ar.,this ground is totally different.In NW,there was alot of rocks,and here no rocks,and dark soil with some sandy loam.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2019 at 10:03am
A 4-14 should work well. I’ve pulled 3-14 with my CA in sod 8” deep. We pull 4-14” behind the 45 and 5-14 behind the D-17. The key to getting the best efficiency use from the equipment is proper setup of the plow and tractor. My CA can pull a 3-14 well, but I had a 2-14 that stopped it dead in its tracks because the plow was way out of adjustment. When the setup is wrong the draft increases which requires more power and traction. The 45 is a 4 bottom tractor. It has power to spare. Traction will be the issue, but with good tread and proper weight you’ll have a great plowing rig. I would recommend fluid in rear tires as well as 1 set of rear wheel weights. This with a working traction booster system will work well. You should also add 1 set of front wheel weights or front stackable weights. There are 4 different plow frames that can be used behind the 45. First is the 50 series which is the most common, but is limited to 3 bottoms. The 60 series is also very common and available up to a 5 bottom. The 70 & 80 series have a lot more trash clearance. They are talller and longer than the 50 & 60 series. The 70 & 80 series are basically the same. The only real difference is that the 80 has spring trips for each bottom. I would also recommend using the 60 series plow frame. If you go with a 70 or 80 series I would recommend a semi-mount type as the length of a 4 bottom would put a lot of weight on the back.
Thanks & God Bless
Dennis
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2019 at 10:12am
I also took the wheel weight off the furrow wheel and doubled up on the on land wheel.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2019 at 3:56pm
Factory shows the 4-14 semi-mount as made for 45. I have one, but use the 3-14 snap-coupler plow on mine, almost wont handle it here in my gardens. I plow 14 to 18 inches deep, and yes a 14" plow will go that deep if set right!
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2019 at 6:21pm
I have a computer version of a manual for WD52 and WD53 plows in this computer. I don't think I can post it where my other Allis manuals are posted, but I can attach it to an e-mail.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhankins Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2019 at 6:47pm
Gerald,email is mikegramps@yahoo.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2019 at 10:50am
Email sent.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2019 at 10:04pm
I pulled a 4-16 snap coupler semi mount w/steering tail wheel 8in deep with my 45 in 2nd gear. Good match except for the clay and gumbo spots. Not much of that  so just lift T/B a little and go on. I did have to remove some washers in the spring of the snap coupler hitch to keep the plow in the ground.Too much draft with that plow and the TB would raise the plow with the lever at bottom
Edited by SteveM C/IL - 17 Mar 2019 at 10:08pm
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2019 at 1:44pm
WD45 Diesel.  3-16's fully mounted with fluid and weights.  pulled in all types of ground.  16" plow had more clearance then the 14" but was far from high clearance.   i plugged it in wheat stubble, more times then i could count!
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2019 at 7:29pm
Pulled a 3x16 snap coupler over lots of acres in every condition except alalafa sod. The sod had been there as long as anybody could remember and was heavily fertilized every year. I had to drop the back bottom on that field.
This page was generated in 0.227 seconds.
