Allis Chalmers Carry All!
DakotaSteve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers Carry All!
    Posted: 28 Feb 2018 at 7:21pm
Post any pics or tell ways that you have used your carry all attachment for! Are they pretty handy? Maybe they weren't very popular and that's why a person doesn't see many?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2018 at 8:18pm
My first D-14 had a trip loader on it. 2 years later, loader was gone and made my own 'carryall' that uses removable forklift forks. One of the handiest things I've ever made! Most of the 'stuff' around here in on skids,so it's real easy to move with the carryall. I back up to a 6by6 and lower the carryall and the forks come off. On the bottom cross member of the rig I have a 2" receiver, where I just toss in a 2" ball to haul trailers, or an empty sleeve to pull discs or farm wagon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 4:21pm
I've hauled everything from junk to the Grandkids.
Barbed wire, 5 gallon buckets of water for the animals, bales of hay, tractor parts, chain saws, wash machines, dryers, VERY used water heaters, golf cart, 3-bottom plow, milk cans, bucked wood, wood stoves, freezer, beer and water, metal siding, shotguns, clay pigeons, shells, chains (tire and log), fence posts, concrete blocks, etc.
I hate to take it off because within 10 minutes I'll need it again.  I'm gonna dedicate one of my WD45 to it.
It's handier than the loader for throwing stuff in to take .......
I was gonna build one but then found this one down in Indiana from tmonroe.  THANKS Tom!!  And he brought it all the way to southern WI so I didn't have to drive all the way down there!!
HARD TO FIND!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 4:38pm
Awesome uses!
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 5:05pm
Not a "carry-all" per se,
but in the 60's when we had fields a distance away, Dad and I built a platform lift for the rotary hoe.  Made it out of bridge planks.
Built our own version of a carry-all which also used the SC and went under the platform like a forklift.
IIRC, the frame was built from F20 side rails and a large pipe with an eye for the SC
It worked great, but made the front end a bit light.....so light that it would come off the ground occasionally......made for some interesting road trips
The next year, we modified the rotary hoe by adding a long pipe across the front with arms that tied to the gangs with chains.
It used the SC feature as well.....just a large T
This turned out to be the best way to do it.  We built a few more for (IH) neighbors
Edited by Gatz in NE - 01 Mar 2018 at 5:08pm
*DougW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote *DougW Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 7:08pm
Used our carry-all in the sixties to haul milk cans through the snow to meet the truck when roads were closed. D-14 with wide front, chains on rear tires, heat houser, good to go!!
kenbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenbob Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 10:41pm
I made this light duty carryall out of left over plywood and a backwards mounted Allis tool bar and threaded rod.  uploads/17647/IMG_0681_2018-03-01_22-41-31.JPG
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenbob Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 10:45pm
uploads/17647/IMG_0685_2018-03-01_22-45-00.JPG
The plywood on top of the above posted hitch
Edited by kenbob - 01 Mar 2018 at 10:45pm
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 7:37pm
This is one I made out of an aftermarket 3 point adapter. Haven't used it nearly as much as I thought I would.
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 9:05pm
Here's how I made mine. Sorry, I have so many pictures on so many different host sites I don't remember where they are, so your getting the whole story-
The mechanic always wins.
This page was generated in 0.254 seconds.
