plow bolt size?
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Topic: plow bolt size?
    Posted: 01 Oct 2017 at 7:33pm
I am wanting to flip the cutting edge on my Oxnard rear blade and was wanting to know if anyone had a source for the 5/8" plow bolts (5/8-11x2") used to fasten the cutting edge to the moldboard. I also wanted to know if anyone knows a source for a replacement cutting edge. Thanks, Tim
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2017 at 7:59pm
As for the bolts, A lot of graders use the same size, 5/8 by X.  Pretty sure fastenall will have them, as well as equipment dealers...
Blade will be a more difficult score...Cry
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2017 at 8:27pm
If they are standard plow bolts, most any farm supply store should have them.
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2017 at 8:32pm
I think there was a post a few years ago about using some Caterpillar cutting edges that were almost a direct replacement and wasn’t overly expensive. Maybe someone will chime in
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2017 at 9:06pm
I looked at mine and don't think it can be flipped, bolt pattern won't match.
TBone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TBone Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2017 at 7:48am
Got mine from Farm & Fleet
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2017 at 9:34am
Shoup says they have 5/8" plow bolts in stock, a whole buck each.
https://www.shoupparts.com/PB58214/
Gerald J.
