Unofficial Allis Homepage
AC 72 2 row planter plugging up
Dan158 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan158 Quote  Post ReplyReply Direct Link To This Post Topic: AC 72 2 row planter plugging up
    Posted: 11 May 2021 at 2:22pm
What's the trick or a mod to keep the seed tube from clogging up. Anyone take a grinder to it.Thank you.    Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2021 at 2:32pm
Parallel arms should be horizontal when planting. Seed box lid must be parallel to the ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan158 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2021 at 8:01pm
Thank you and I will make sure all is on the level. One more question, How does one get the back wheel to cover the seed. I have seen videos where the back wheel doesn't cover the seed especially on the no till ones on non disked or tilled ground. Thank you.Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2021 at 8:27pm
There are/were attachments to help with that, such as dragging a twisted chain behind the drive wheel, different shapes of wheels etc. The first thing to do is SLOW DOWN. No-till can't be fast.....drive 3 MPH instead of 5 MPH.
wheelbilly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheelbilly Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2021 at 9:44pm
Worn disk openers are a main contributor to plugging the seed tube.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2021 at 8:00am
Worn disc openers indeed will cause this plugging. The disc openers must be large enough in diameter that they actually touch/pinch together at some point to keep soil from getting in-between them. You represented this planter as being rebuilt. I would think the disc openers weren't worn out, but maybe they are.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan158 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2021 at 10:36am
Yes everything is almost as good as new. The reason I asked is because I let it sit and sank into the wet ground and the seed shoot got clogged.The soil where it was sitting.Not sure if should of clogged from just sinking about 2 or 3 inches on the one side..Yes the disk are touching at the bottom or real close..
Edited by Dan158 - 12 May 2021 at 10:37am
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2021 at 8:20am
make sure you are moving in a forward direction before lowering planter,  also do not let tractor roll back if stopping to raise planter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2021 at 3:39am
X2 what JoeO says, also check inside tubes for spider nests/webs, that will always cause plugging.
