7060 rim |
Post Reply |
kjs
Bronze Level Joined: 24 Jan 2020 Location: NE Nebraska Points: 46 |
Posted: 12 May 2021 at 7:19pm |
I have the rim on a rear tire that is somewhat rotted out around the valve stem hole. Is it possible to section out a piece and replace?
victoryallis
Orange Level Joined: 15 Apr 2010 Location: Ludington mi Points: 2855 |
I’ve seen it done successfully
plummerscarin
Orange Level Access Joined: 22 Jun 2015 Location: ia Points: 3112 |
I've done it for a 170
kjs
Did you use just mild steel for the repair
plummerscarin
I cut the patch from a WD rim that was too far gone. After the patch was welded in, I then heated the area where the valve stem goes through and recreated the flat spot. Then drilled the hole for the stem.
Michael V (NM)
Orange Level Access Joined: 12 Sep 2009 Location: NM Points: 2335 |
if its a 38" rim,, ya might check the center pivot places for a wrecked wheel, usually the centers are what is bad on them and the stem hole is good, cause they don't run calcium, cut a section and weld it in,,,I jus done this on a 38" spin out wheel,, works good
steve fischer
Orange Level Joined: 11 Jul 2011 Location: sleepy eye mn Points: 927 |
have new ones
Post Reply | |
